| Javascript Validation [message #547123] |
Thu, 15 July 2010 11:54  |
Tobias Willig Messages: 5 Registered: July 2010 |
Junior Member |
I got a problem with the javascript validation, it does not work in HTML files. I'm using the eclipse HTML editor. Auto-completion and syntax highlighting are fully functional. The javascript validation works fine in the javascript editor. My eclipse version is Helios.
Is there a way to enable javascript validation for the HTML editor?
| Re: Javascript Validation [message #547592 is a reply to message #547123] |
Mon, 19 July 2010 02:25  |
Nitin Dahyabhai Messages: 1860 Registered: July 2009 |
On 7/15/2010 11:54 AM, Twilli wrote:
> Hello,
Is your project enabled for JavaScript and the web page in the
JavaScript Include Path? If the project's not enabled for JavaScript at
all, a quick trip to its Configure context menu should do the trick.
Otherwise, check the JavaScript Include Path property page on the
project and make sure you've defined a Source folder.
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
Nitin Dahyabhai
Eclipse WTP, IBM
FUDForum. Page generated in 0.01718 seconds
