we want to generate a report from EPF models. On top of the report,
there should be the name of the model. I tried to define a separate data
source and data set just containing one row with the title. Then, I
tried to include the dataset row via a dynamic text field. However,
nothing is displayed.
Is this the right approach? What am I missing?
Patrick
email: pschoenb@gmx.de
PGP public key available. Key ID: 0B7DDE39
Or email to pgp@robustsoft.de with subject 'pschoenb'.
Fingerprint: BE80 0E7E B68E CE99 623C 902D 62A6 806A 0B7D DE39
You need to bind the dynamic text element to the data set you've created, if you haven't done so. Then specify a value for it via "Available Column Bindings" in Expression Builder. I hope that helps.
