| Layout problem [message #547128] |
Thu, 15 July 2010 11:54  |
Originally posted by: pschoenb.gmx.de
my report layout is as follows and I want to render the report to PDF:
header
| name 1 | data 1 |
| name 2 | data 2 |
The "data" column consists of lots of HTML text. However, as soon as I
insert the data column, all fonts become unreadable small and the table
width then is only about a teneth of the paper width.
What could be wrong?
Patrick
email: pschoenb@gmx.de
PGP public key available. Key ID: 0B7DDE39
Or email to pgp@robustsoft.de with subject 'pschoenb'.
Fingerprint: BE80 0E7E B68E CE99 623C 902D 62A6 806A 0B7D DE39
| Re: Layout problem [message #547151 is a reply to message #547130] |
Thu, 15 July 2010 13:11   |
On Thu, 15 Jul 2010 12:06:10 -0400, Richard A. Polunsky wrote:
> I suspect either CSS or other style interactions.
> Remove all styling and make sure you have no CSS references, then run
> the report in HTML and also in PDF. See if the issue still arises
> and whether it appears in all types of report elements or only in
> specific ones. Also, what are the master page specifications in your
> report?
I have no styling except that I have specified fonts and font sizes. As
soon as I remove the HTML content, fonts become larger but still too
small. However, the width of the page content is still much too small.
Patrick
FUDForum. Page generated in 0.05179 seconds
