Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Emfatic] Help with namespace warning.
[Emfatic] Help with namespace warning. [message #546821] Wed, 14 July 2010 06:33 Go to next message
Toñi Reina is currently offline Toñi Reina
--------------030404000208030002020909
Hi all,
I'm just starting to define emf with Emfatic. I'm testing the tool with
a metamodel that has various packages, similar to the following one:
@namespace(uri="http://org.test",prefix="test")
@gmf(foo="bar")
package test;
package testA{
The question is related to a warning that appears in Emfatic when I
write the first subpackage. That is, if the code is the one shown below
(without the subpackage) the warning does not appear. However, when I
introduce the subpackges it is there.
@gmf(foo="bar")
package test;
The warning reports about a null uri and a null prefix in the namespace.
However, these properties are set, as you can see above.
I have attached a screenshot to see the warning better.
To
Re: [Emfatic] Help with namespace warning. [message #546871 is a reply to message #546821] Wed, 14 July 2010 09:17 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
--------------010007040901010002040408
To
Re: [Emfatic] Help with namespace warning. [message #547042 is a reply to message #546871] Thu, 15 July 2010 04:24 Go to previous messageGo to next message
Thanks Ed,
that was the exact problem. I supposed EMF could obtain the
subpackages namespace automatically, so I didn't write any @namespace
label attached to the supackages.
Toñi
El 14/07/2010 15:17, Ed Merks escribió:
> Toñi,
> I imagine the package testA needs its own @namespace annotation.
> Toñi Reina Quintero wrote:
>> Hi all,
>> with a metamodel that has various packages, similar to the following one:
>> @gmf(foo="bar")
>> package test;
>> package testA{
>> below (without the subpackage) the warning does not appear. However,
>> when I introduce the subpackges it is there.
>> @gmf(foo="bar")
>> package test;
>> namespace. However, these properties are set, as you can see above.
>> Best regards,
>> Toñi Reina
Re: [Emfatic] Help with namespace warning. [message #547068 is a reply to message #547042] Thu, 15 July 2010 09:06 Go to previous message
Toñi,
Indeed. I expect the nsPrefix (prefix) could have been determined from
the name as a very reasonable default as well.
> Thanks Ed,
> Toñi
>> Toñi,
>>> Hi all,
>>> one:
>>> @gmf(foo="bar")
>>> package test;
>>> package testA{
>>> @gmf(foo="bar")
>>> package test;
>>> Best regards,
>>> Toñi Reina
Re: [Emfatic] Help with namespace warning. [message #623058 is a reply to message #546821] Wed, 14 July 2010 09:17 Go to previous message
To
Re: [Emfatic] Help with namespace warning. [message #623063 is a reply to message #546871] Thu, 15 July 2010 04:24 Go to previous message
Thanks Ed,
Toñi
> Toñi,
>> Hi all,
>> @gmf(foo="bar")
>> package test;
>> package testA{
>> @gmf(foo="bar")
>> package test;
>> Best regards,
>> Toñi Reina
Re: [Emfatic] Help with namespace warning. [message #623064 is a reply to message #547042] Thu, 15 July 2010 09:06 Go to previous message
Toñi,
> Thanks Ed,
> Toñi
>> Toñi,
>>> Hi all,
>>> one:
>>> @gmf(foo="bar")
>>> package test;
>>> package testA{
>>> @gmf(foo="bar")
>>> package test;
>>> Best regards,
>>> Toñi Reina
Previous Topic:ebedded emftext editor
Next Topic:[WME] How to enable logging in WME WorkflowRunner?
Current Time: Sat May 25 20:34:58 EDT 2013
Powered by FUDForum. Page generated in 0.01977 seconds
