| Emitter file extension [message #546827] |
Wed, 14 July 2010 07:16  |
moloco Messages: 7 Registered: March 2010 |
Junior Member |
Hi all. Sorry for my bad EN_en
I made new emitter for ancient DBF format.
I duplicate "cvs/xml examples" emitter "initialize()" method, change format to "dbf" and mimeType to "application/dbase" , but when i try to get report, i receive file without extension ".dbf"
when i'm debug project, i see in "initialize()"
Object value = service.getOption(RenderOption.OUTPUT_STREAM)
and value is CoyoteOutputStream with header "filename=nameWithoutExtension"
What i do wrong?
| Re: Emitter file extension [message #546980 is a reply to message #546827] |
Wed, 14 July 2010 15:20  |
Jason Weathersby Messages: 9167 Registered: July 2009 |
Did you add an extension setting to the viewer.properties file in the
viewer?
# [EXTENSION SETTING]
viewer.extension.html=html
viewer.extension.pdf=pdf
viewer.extension.postscript=ps
viewer.extension.doc=doc
viewer.extension.xls=xls
viewer.extension.ppt=ppt
Jason
> I made new emitter for ancient DBF format. I duplicate "cvs/xml
> Object value = service.getOption(RenderOption.OUTPUT_STREAM) and value
> What i do wrong?
Jason Weathersby
BIRT Exchange
FUDForum. Page generated in 0.04759 seconds
