Home » Eclipse Projects » P2 » P2 Update Fails After Port from 3.5 to 3.6 Helios
P2 Update Fails After Port from 3.5 to 3.6 Helios [message #546474] Mon, 12 July 2010 22:28
Michael Yara is currently offline Michael Yara
I am in the process of porting our RCP application from 3.5 to Helios 3.6. During my port I discovered that the P2 API has changed significantly and I modified my headless update code to take advantage of the new API along with the UpdateOperation class. I found that updating from a version of our application that is using 3.5 to a version that is using 3.6 works perfectly fine however once I attempt to upgrade once more to another higher version of our application that is using 3.6 I get the following status error report.
!ENTRY org.eclipse.equinox.p2.operations 4 0 2010-07-12 20:19:14.135
!MESSAGE Operation details
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 1 2010-07-12 20:19:14.135
!MESSAGE Cannot complete the install because of a conflicting dependency.
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 0 2010-07-12 20:19:14.135
!MESSAGE Software being installed: iSymphony 2.2.0.2131 (isymphony 2.2.0.2131)
!MESSAGE Software currently installed: ClientRCP Plug-in 2.2.0.2130 (ClientRCP 2.2.0.2130)
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 1 2010-07-12 20:19:14.135
!MESSAGE Only one of the following can be installed at once:
!SUBENTRY 3 org.eclipse.equinox.p2.director 4 0 2010-07-12 20:19:14.135
!MESSAGE ClientRCP Plug-in 2.2.0.2130 (ClientRCP 2.2.0.2130)
!MESSAGE ClientRCP Plug-in 2.2.0.2131 (ClientRCP 2.2.0.2131)
!MESSAGE Cannot satisfy dependency:
!MESSAGE From: iSymphony Feature 2.2.0.2131 (iSymphonyFeature.feature.group 2.2.0.2131)
!MESSAGE To: ClientRCP [2.2.0.2131]
!MESSAGE From: iSymphony 2.2.0.2131 (isymphony 2.2.0.2131)
!MESSAGE To: iSymphonyFeature.feature.group [2.2.0.2131]
Note that if I start with the version that contains 3.6 already I can update to my hearts content. It seems as if p2 is trying to do an install instead of a update. I have attched my update class code below. Is there any additional information I can provide that may be of use in assisting me with resolving this issue?
Best Regards,
Mike
package com.xmlnamespace.operatorpanel.update;
import java.io.File;
import java.lang.reflect.InvocationTargetException;
import java.net.MalformedURLException;
import java.net.URI;
import java.net.URISyntaxException;
import java.net.URL;
import java.util.concurrent.Semaphore;
import org.eclipse.core.runtime.IProgressMonitor;
import org.eclipse.core.runtime.IStatus;
import org.eclipse.core.runtime.OperationCanceledException;
import org.eclipse.core.runtime.SubMonitor;
import org.eclipse.equinox.internal.p2.core.helpers.ServiceHelper;
import org.eclipse.equinox.p2.core.IProvisioningAgent;
import org.eclipse.equinox.p2.core.ProvisionException;
import org.eclipse.equinox.p2.operations.ProvisioningJob;
import org.eclipse.equinox.p2.operations.ProvisioningSession;
import org.eclipse.equinox.p2.operations.Update;
import org.eclipse.equinox.p2.operations.UpdateOperation;
import org.eclipse.equinox.p2.repository.artifact.IArtifactRepositoryManager;
import org.eclipse.equinox.p2.repository.metadata.IMetadataRepositoryManager;
import org.eclipse.jface.dialogs.MessageDialog;
import org.eclipse.jface.dialogs.ProgressMonitorDialog;
import org.eclipse.jface.operation.IRunnableWithProgress;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.ui.PlatformUI;
@SuppressWarnings("restriction")
public class Updater {
	//Shell
	private Shell shell = null;
	//Update lock semaphores
	private Semaphore updateLock = null;
	//Update workers
	private IProvisioningAgent provisioningAgent = null;
	private IMetadataRepositoryManager metadataManager = null;
	private IArtifactRepositoryManager artifactManager = null;
	//Constructor------------------------------------------------------------------------------------------------------------------------------------
	public Updater(Shell shell) {
		this.shell = shell;
		updateLock = new Semaphore(1);
	//Update methods---------------------------------------------------------------------------------------------------------------------------------
	public void updateFromURL(String updateLocation) {
		try {
			URI uri = new URL(updateLocation).toURI();
			//If an update occurred prompt for restart
			if(updateCore(uri)) {
				openRestart();
		} catch(URISyntaxException URIse) {
			openError(Messages.Updater_update_failed_label, Messages.Updater_update_location_path_malformed_label + ":" + updateLocation);
			UpdateLog.logErrorNoPopup(Messages.Updater_update_failed_label + ":" + updateLocation, URIse);
		} catch(MalformedURLException MURLe) {
			UpdateLog.logErrorNoPopup(Messages.Updater_update_failed_label + ":" + updateLocation, MURLe);
	public void updateFromFile(String updateLocation) {
		//Check for path existence
		File updatePath = new File(updateLocation);
		if(updatePath.exists()) {
			if(updateCore(updatePath.toURI())) {
				openRestart();
		} else {
			Messages.Updater_update_path_does_not_exist_label + ":" + updateLocation);
	private boolean updateCore(final URI repoLocation) {
		//Create update progress bar runnable
		IRunnableWithProgress updateProgressRunnable = new IRunnableWithProgress() {
			public void run(IProgressMonitor monitor) throws InvocationTargetException, InterruptedException {
				//Check if repo location was provided
				if(repoLocation == null) {
					Throwable throwable = new Throwable(Messages.Updater_no_repositories_provided_label);
					throwable.fillInStackTrace();
					throw new InvocationTargetException(throwable);
				//Load provisioning agent
				provisioningAgent = (IProvisioningAgent) ServiceHelper.getService(Activator.bundleContext, IProvisioningAgent.SERVICE_NAME);
				if (provisioningAgent == null) {
					Throwable throwable = new Throwable(Messages.Updater_could_not_load + " Provisioning Agent");
				//Load repository manager
				metadataManager = (IMetadataRepositoryManager) provisioningAgent.getService(IMetadataRepositoryManager.SERVICE_NAME);
				if(metadataManager == null) {
					Throwable throwable = new Throwable(Messages.Updater_could_not_load + " Metadata Repository Manager");
				//Load artifact manager
				artifactManager = (IArtifactRepositoryManager) provisioningAgent.getService(IArtifactRepositoryManager.SERVICE_NAME);
				if(artifactManager == null) {
					Throwable throwable = new Throwable(Messages.Updater_could_not_load + " Artifact Repository Manager");
				//Convert monitor
				SubMonitor mainMonitor = SubMonitor.convert(monitor, "Checking for application updates...", 300);
				//Load repo
				try {
					metadataManager.loadRepository(repoLocation, null);
					artifactManager.loadRepository(repoLocation, null);
				} catch (ProvisionException pe) {
					throw new InvocationTargetException(pe);
				//Create update session and operation
				ProvisioningSession session = new ProvisioningSession(provisioningAgent);
				UpdateOperation operation = new UpdateOperation(session);
				//Check for updates
				IStatus status = operation.resolveModal(mainMonitor.newChild(100));
				//If updates were not found throw exception
				if(status.getCode() == UpdateOperation.STATUS_NOTHING_TO_UPDATE) {
					throw new InvocationTargetException(new NoUpdatesFoundException());
				//If update was canceled throw exception
				if(status.getSeverity() == IStatus.CANCEL) {
					throw new OperationCanceledException();
				//If update check errored out throw exception
				if(status.getSeverity() == IStatus.ERROR) {
					throw new InvocationTargetException(new StatusException(status));
				//Execute update
				ProvisioningJob job = operation.getProvisioningJob(null);
				status = job.runModal(mainMonitor.newChild(100));
		//Check update lock
		if(!updateLock.tryAcquire()) {
			return false;
		//Run update progress dialog
		boolean updated = false;
		try {
			final ProgressMonitorDialog updateProgressDialog = new ProgressMonitorDialog(shell);
			updateProgressDialog.open();
			updateProgressDialog.getShell().setText("Updating");
			updateProgressDialog.run(true, true, updateProgressRunnable);
			updated = true;
		} catch(InvocationTargetException ite) {
			//Show error that occurred
			if(ite.getTargetException() instanceof NoUpdatesFoundException) {
				openInformation(Messages.Updater_application_up_to_date_label, Messages.Updater_application_is_up_to_date_label);
			} else if(ite.getTargetException() instanceof StatusException) {
				IStatus status = ((StatusException)ite.getTargetException()).getStatus();
				openError(Messages.Updater_update_failed_label, status.getMessage());
				UpdateLog.log(status);
			} else {
				openError(Messages.Updater_update_failed_label, ite.getTargetException().getMessage());
				UpdateLog.logErrorNoPopup(Messages.Updater_update_failed_label, ite.getTargetException());
		} catch(InterruptedException ie) {
			//Operation was canceled do nothing
		} finally {
			//Cleanup
			if(metadataManager != null) {
				metadataManager.removeRepository(repoLocation);
			if(artifactManager != null) {
				artifactManager.removeRepository(repoLocation);
			if(provisioningAgent != null) {
				provisioningAgent.stop();
			updateLock.release();
		return updated;
	//Helper methods---------------------------------------------------------------------------------------------------------------------------------
	private void openRestart() {
		Display.getDefault().syncExec( new Runnable() {
			public void run() {
				MessageDialog.openInformation(shell, Messages.Updater_update_successful_label, Messages.Updater_a_restart_is_requierd_for_updates_to_take_effect_label);
		PlatformUI.getWorkbench().restart();
	private void openError(final String title, final String body) {
		Display.getDefault().asyncExec( new Runnable() {
			public void run() {
				MessageDialog.openError(shell, title, body);
	private void openInformation(final String title, final String body) {
			public void run() {
				MessageDialog.openInformation(shell, title, body);
Previous Topic:Multipe URLs in p2.repo property of runDirector task
Next Topic:P2 Update Fails After Port from 3.5 to 3.6 Helios
Current Time: Tue Jun 18 03:55:18 EDT 2013
Powered by FUDForum. Page generated in 0.01439 seconds
