Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Listening to checking/unchecking of TableItems
icon5.gif  Listening to checking/unchecking of TableItems [message #546108] Sun, 11 July 2010 01:41 Go to next message
Alexey Romanov is currently offline Alexey Romanov
Which type of event is triggered when a TableItem (in a Table created with SWT.CHECK style) is checked or unchecked?
Re: Listening to checking/unchecking of TableItems [message #546122 is a reply to message #546108] Sun, 11 July 2010 07:40 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas Schindl
SWT.Selection with detail set to SWT.CHECK
Tom
Am 11.07.10 07:41, schrieb Alexey Romanov:
Re: Listening to checking/unchecking of TableItems [message #546123 is a reply to message #546122] Sun, 11 July 2010 07:56 Go to previous messageGo to next message
Thanks! Does it fire before or after the state changes? That is, will setting `event.doit = false` work?
Re: Listening to checking/unchecking of TableItems [message #546135 is a reply to message #546123] Sun, 11 July 2010 10:19 Go to previous messageGo to next message
after! See
http://tomsondev.bestsolution.at/2008/10/08/disable-parts-sw t-tabletree-with-swt-check/
Tom
Am 11.07.10 13:56, schrieb Alexey Romanov:
Re: Listening to checking/unchecking of TableItems [message #546136 is a reply to message #546135] Sun, 11 July 2010 10:48 Go to previous messageGo to next message
Thanks again!
(I believe
TreeItem item = (TreeItem)tree.item;
should say event.item instead)
Re: Listening to checking/unchecking of TableItems [message #546137 is a reply to message #546136] Sun, 11 July 2010 11:17 Go to previous message
Am 11.07.10 16:48, schrieb Alexey Romanov:
> Thanks again!
> (I believe
yes
Previous Topic:Resize elements in SWT Shell at runtime
Next Topic:SWT tree: auto resize all columns
Current Time: Mon May 20 15:44:08 EDT 2013
Powered by FUDForum. Page generated in 0.01707 seconds
