Home » Modeling » Epsilon » EWL Guard Querying Stereotype
EWL Guard Querying Stereotype [message #545848] Fri, 09 July 2010 08:04 Go to next message
Bak Attila is currently offline Bak Attila
I have the following problem in EWL:
I would like to know if a class has a certain stereotype.
Unfortunately my tries are not working like:
guard: (self.isKindOf(Class) and (self.getAppliedStereotype("x") <> null))
Please help!
attila
Re: EWL Guard Querying Stereotype [message #545852 is a reply to message #545848] Fri, 09 July 2010 08:07 Go to previous messageGo to next message
Dimitrios Kolovos is currently offline Dimitrios Kolovos
Hi Attila,
Assuming that you have defined the getAppliedStereotype() method (as
there's no such built-in method in Epsilon), the way to check whether it
has returned null is to use the isDefined() method: i.e.
self.getAppliedStereotype("x").isDefined()
Dimitris
Bak Attila wrote:
> Please help!
> Thanks
> attila
Re: EWL Guard Querying Stereotype [message #545854 is a reply to message #545852] Fri, 09 July 2010 08:28 Go to previous messageGo to next message
Thanks! Works like a charm! Smile
I just wanted to thank you for this wonderful project Epsilon!
Great Job keep up the superb work!
regards,
attila
Re: EWL Guard Querying Stereotype [message #545864 is a reply to message #545854] Fri, 09 July 2010 09:09 Go to previous message
Great! Many thanks for your feedback :)
Dimitris
Bak Attila wrote:
> Thanks! Works like a charm! :)
> regards,
> attila
Re: EWL Guard Querying Stereotype [message #590556 is a reply to message #545852] Fri, 09 July 2010 08:28 Go to previous message
regards,
attila
Re: EWL Guard Querying Stereotype [message #590563 is a reply to message #545854] Fri, 09 July 2010 09:09 Go to previous message
Dimitris
> regards,
> attila
Previous Topic:EWL Guard Querying Stereotype
Next Topic:[Eugenia] Newbie question. Problems in the generated editor with the Folder Item.
Current Time: Thu May 23 08:02:34 EDT 2013
Powered by FUDForum. Page generated in 0.01611 seconds
