Home » Modeling » B3 » Aggregator: Transformation failed: null
Aggregator: Transformation failed: null [message #545570] Thu, 08 July 2010 05:34 Go to next message
Carsten Reckord is currently offline Carsten Reckord
Hi there,
Now that Helios is out, I'm finally trying to switch from the old Buckminster Aggregator version to the new B3 one. However, in the
Transformation wizard for the Aggregator build file, the transformation stops with "Transformation error: null". No further information is
given in the error log. Is there anything noteworthy to check for/avoid in my old build file to get that transformation running?
Carsten
Re: Aggregator: Transformation failed: null [message #545586 is a reply to message #545570] Thu, 08 July 2010 06:20 Go to previous messageGo to next message
I just found http://wiki.eclipse.org/Eclipse_b3/aggregator/Migration_From _buckminster and converted manually. Everything working fine now.
On 08.07.2010 11:34, Carsten Reckord wrote:
> Hi there,
> Cheers,
> Carsten
Re: Aggregator: Transformation failed: null [message #545659 is a reply to message #545586] Thu, 08 July 2010 10:06 Go to previous message
Filip Hrbek is currently offline Filip Hrbek
Try the latest from http://download.eclipse.org/modeling/emft/b3/updates-3.7mile stones
This bug should be fixed there.
Filip
Dne 8.7.2010 12:20, Carsten Reckord napsal(a):
> I just found
>> Hi there,
>> information is
>> Cheers,
>> Carsten
Re: Aggregator: Transformation failed: null [message #611597 is a reply to message #545570] Thu, 08 July 2010 06:20 Go to previous message
> Hi there,
> Cheers,
> Carsten
Re: Aggregator: Transformation failed: null [message #611600 is a reply to message #545586] Thu, 08 July 2010 10:06 Go to previous message
Filip
> I just found
>> Hi there,
>> information is
>> Cheers,
>> Carsten
Previous Topic:Aggregator: Transformation failed: null
Next Topic:Unable to build Helios release with b3
Current Time: Thu May 23 06:06:07 EDT 2013
Powered by FUDForum. Page generated in 0.01648 seconds
