Home » Eclipse Projects » P2 » Huge export size of RCP p2 enabled product
Huge export size of RCP p2 enabled product [message #544950] Tue, 06 July 2010 04:13 Go to next message
Marcel A. is currently offline Marcel A.
I like to use the new p2 interface for my rcp application.
I can successfully export my application (product based)
but the size of the export is really huge in contrast to the export
of the application with the old update manager (old: 130 mb new: ca. 450 mb).
What i don't understand is that the plugins are available two times (in the plugins folder and also as *.jars in the repository/plugins folder).
Do i need the *.jars (plugins) in the repository folder? Is there a way to decrease the export size of an rcp application?
Any help is appreciated!
Re: Huge export size of RCP p2 enabled product [message #545066 is a reply to message #544950] Tue, 06 July 2010 10:47 Go to previous messageGo to next message
Andrew Niefer is currently offline Andrew Niefer
When you export your product with p2 metadata, you are actually getting two
things: your product and a p2 repository that contains your product.
You can take the repository/ folder and put it somewhere so people can do
updates when build future versions, you don't need to keep it with the
eclipse/ folder that contains the product itself.
> mb). What i don't understand is that the plugins are available two times
> folder). Do i need the *.jars (plugins) in the repository folder? Is there
Re: Huge export size of RCP p2 enabled product [message #545199 is a reply to message #545066] Wed, 07 July 2010 02:58 Go to previous messageGo to next message
So i can ship the RCP product without the repository/ but with a full functioning p2 update manager for third party plugins?
Re: Huge export size of RCP p2 enabled product [message #545395 is a reply to message #545199] Wed, 07 July 2010 11:37 Go to previous messageGo to next message
Yes, you only need to ship the eclipse/ folder.
In particular, it is the eclipse/p2/ folder that is required for a
functioning p2 update manager.
Re: Huge export size of RCP p2 enabled product [message #545656 is a reply to message #545395] Thu, 08 July 2010 10:16 Go to previous message
Thank you very much for this useful information and your fast reply.
Marcel
Re: Huge export size of RCP p2 enabled product [message #561604 is a reply to message #545066] Wed, 07 July 2010 02:58 Go to previous message
Re: Huge export size of RCP p2 enabled product [message #561639 is a reply to message #545199] Wed, 07 July 2010 11:37 Go to previous message
Re: Huge export size of RCP p2 enabled product [message #561658 is a reply to message #545395] Thu, 08 July 2010 10:16 Go to previous message
Marcel
Previous Topic:Copying across executables as part of P2 installation
Next Topic:Multipe URLs in p2.repo property of runDirector task
Current Time: Sat May 25 10:12:21 EDT 2013
Powered by FUDForum. Page generated in 0.01755 seconds
