Home » Eclipse Projects » BIRT » Font sizes larger in 2.6 than in 2.3?
Font sizes larger in 2.6 than in 2.3? [message #545504] Thu, 08 July 2010 02:03 Go to next message
Juergen Schwarz is currently offline Juergen Schwarz
We're just switching from BIRT 2.3 to 2.6 and noticed that all texts in
PDF output come out much larger in 2.6 than they were in 2.3.
We use our own font, so the font itself cannot be the problem.
Is there any "global" setting in BIRT to reduce the font size? Our
several customers have lots of reports and we cannot re-work them all.
Re: Font sizes larger in 2.6 than in 2.3? [message #545514 is a reply to message #545504] Thu, 08 July 2010 02:48 Go to previous messageGo to next message
Found the cause:
In method getMediumFontSize() of class
org.eclipse.birt.report.engine.css.engine.BIRTCSSEngine the default
medium font size had been changed from 9pt to 12pt. I suppose there is
no other way to get the old sizes other than changing it back to 9 in
the source?
Am 08.07.2010 08:03, schrieb Juergen Schwarz:
Re: Font sizes larger in 2.6 than in 2.3? [message #545884 is a reply to message #545514] Fri, 09 July 2010 10:15 Go to previous message
Jason Weathersby is currently offline Jason Weathersby
Can you open a bug for this? You could also create a css sheet with the
defaults you want and import them into the reports.
Jason
On 7/8/2010 2:48 AM, Juergen Schwarz wrote:
> Found the cause:
> the source?
Jason Weathersby
BIRT Exchange
Previous Topic:ScriptedDatasource report
Next Topic:Graphic Emitter?
Current Time: Wed May 22 20:35:15 EDT 2013
Powered by FUDForum. Page generated in 0.01581 seconds
