| Creating Graphviz "Record" shape in Draw2D [message #545088] |
Tue, 06 July 2010 11:16  |
Namratha Messages: 6 Registered: July 2010 |
Junior Member |
I am able to create most of the graphviz shapes that are related to polygons (like trapezium, inverted trapezium and the like) in Draw2d.
But i dont know how to create the "record" shape available in Graphviz using Draw2d, as this shape needs to be variable. There is nothing fixedin the record shape.
So please if any of you know how it can be drawn in Draw2d, just help me out in this?
Namratha
| Re: Creating Graphviz "Record" shape in Draw2D [message #545280 is a reply to message #545266] |
Wed, 07 July 2010 07:03   |
Vijay Raj Messages: 605 Registered: July 2009 |
u have to parse each structure and accordingly u have to create the figure...
u have write the logic,try it out....
mean while i will try to impliment structure for
"hello\nworld |{ b |{c|<here> d|e}| f}| g | h"
and will post the code in one or two days...(if i am able to)
but after that there will be many hurdels to completly implement records u have to manage that...
why, mr. Anderson, why, why do you persist?
Because I Choose To.
Vijay
| Re: Creating Graphviz "Record" shape in Draw2D [message #545447 is a reply to message #545363] |
Wed, 07 July 2010 15:34   |
you have to extend shapes class and draw each compartments according to the specified script....
how did u manage to do box3d, component, Mcircle,note, tab folder etc..
if you could manage these then u should be able to do this also..
Vijay
| Re: Creating Graphviz "Record" shape in Draw2D [message #545579 is a reply to message #545532] |
Thu, 08 July 2010 06:14   |
Not much but Shapes is much more generic way to create shapes,
u have to just override fillShape and outlineShape and implement it.
u can see RectangularFigure and Ellipse for specifics...
for example
package org.eclipse.gef.examples.flow;
import org.eclipse.draw2d.Figure;
import org.eclipse.draw2d.Graphics;
import org.eclipse.draw2d.LightweightSystem;
import org.eclipse.draw2d.Shape;
import org.eclipse.draw2d.XYLayout;
import org.eclipse.draw2d.geometry.Insets;
import org.eclipse.draw2d.geometry.Rectangle;
import org.eclipse.swt.widgets.Shell;
* A test class to display a UMLFigure
public class StructureShape
public static void main(String args[])
Display d = new Display();
final Shell shell = new Shell(d);
shell.setSize(400, 400);
shell.setText("UMLClassFigure Test");
LightweightSystem lws = new LightweightSystem(shell);
Figure contents = new Figure();
XYLayout contentsLayout = new XYLayout();
contents.setLayoutManager(contentsLayout);
Structure c = new Structure();
c.setBounds(new Rectangle(50, 50, 200, 100));
contents.add(c);
lws.setContents(contents);
shell.open();
while (!shell.isDisposed())
while (!d.readAndDispatch())
d.sleep();
public static class Structure extends Shape
protected void fillShape(Graphics graphics)
graphics.fillRectangle(bounds.getCopy().crop(new Insets(1, 1, 1, 1)));
protected void outlineShape(Graphics graphics)
Rectangle copy = bounds.getCopy();
copy = copy.crop(new Insets(1, 1, 1, 1));
graphics.drawRectangle(copy);
graphics.drawLine(copy.x + copy.width / 3, copy.y, copy.x + bounds.width / 3, copy.y
+ copy.height);
graphics.drawLine(copy.x + copy.width * 2 / 3, copy.y, copy.x + copy.width * 2 / 3,
copy.y + copy.height);
graphics.drawLine(copy.x + copy.width / 3, copy.y + copy.height / 3, copy.x
+ bounds.width * 2 / 3, copy.y + copy.height / 3);
graphics.drawLine(copy.x + copy.width / 3, copy.y + copy.height * 2 / 3, copy.x
+ bounds.width * 2 / 3, copy.y + copy.height * 2 / 3);
here the fraction which are multiplied will be decided by the structure script.
and how many times also will be decided by the script.
Vijay
| Re: Creating Graphviz "Record" shape in Draw2D [message #545776 is a reply to message #545655] |
Fri, 09 July 2010 01:20   |
The version of draw2d was 3.6 here,
u can remove the crop methods and do the crop manually,
The script is
digraph structs {
node [shape=record];
struct1 [label="<f0> left|<f1> mid\ dle|<f2> right"];
struct2 [label="<f0> one|<f1> two"];
struct3 [label="hello\nworld |{ b |{c|<here> d|e}| f}| g | h"];
struct1:f1 -> struct2:f0;
struct1:f2 -> struct3:here;
in purticular
which decides how many columns(sub columns) and rows(sub rows)
but as i told u
| Quote: | but after that there will be many hurdels to completly implement records u have to manage that...
even if i want to help i will not be able to cuz there are many things to take care of...i can not dectate them from here...
Vijay
FUDForum. Page generated in 0.01962 seconds
