Home » Eclipse Projects » EPF » Error opening the editor - Error abriendo el Editor(ubuntu 10.04 error opening the editor )
icon8.gif  Error opening the editor - Error abriendo el Editor [message #544907] Mon, 05 July 2010 22:41
Mario Andr is currently offline Mario Andr
Hello, when I try to create a new role it generates a java error that I can create roles, someone know how you can solve this problem?
Hola, cuando trato de crear un nuevo rol me genera un error de java que no me permite crear los roles, alguien sabe como se puede solucionar este problema?
Ubuntu 10.04
JRE 1.5.0.4
JDK 1.5..0.4
Description to the error:...
__________________________________________
at org.eclipse.epf.authoring.ui.forms.DescriptionFormPage.dispo se(DescriptionFormPage.java:3092)
at org.eclipse.ui.forms.editor.FormEditor.dispose(FormEditor.ja va:420)
at org.eclipse.epf.authoring.ui.editors.AbstractBaseFormEditor. dispose(AbstractBaseFormEditor.java:97)
at org.eclipse.epf.authoring.ui.editors.MethodElementEditor.dis pose(MethodElementEditor.java:1103)
at org.eclipse.epf.authoring.ui.editors.MethodElementEditor.add Pages(MethodElementEditor.java:1041)
at org.eclipse.ui.forms.editor.FormEditor.createPages(FormEdito r.java:146)
at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:283)
at org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
at org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:29 9)
at org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:179)
at org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:400)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1209)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:16 04)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103 )
at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112 )
at org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:63)
at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:217)
at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:207)
at org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:774)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:673)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:634)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2737)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2651)
at org.eclipse.ui.internal.WorkbenchPage.access$13(WorkbenchPag e.java:2643)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2595)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2590)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2574)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2557)
at org.eclipse.epf.authoring.ui.editors.EditorChooser.openEdito r(EditorChooser.java:241)
at org.eclipse.epf.authoring.ui.editors.EditorChooser.openEdito r(EditorChooser.java:167)
at org.eclipse.epf.authoring.ui.UIActionDispatcher$1.doubleClic k(UIActionDispatcher.java:129)
at org.eclipse.epf.authoring.ui.UIActionDispatcher.handleDouble ClickEvent(UIActionDispatcher.java:300)
at org.eclipse.epf.authoring.ui.views.LibraryView$8.doubleClick (LibraryView.java:563)
at org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredV iewer.java:799)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:857)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:46)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:19 9)
at org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(S tructuredViewer.java:797)
at org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSel ect(AbstractTreeViewer.java:1387)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSe lected(StructuredViewer.java:1173)
at org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEven t(OpenStrategy.java:237)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.ja va:234)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:295)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1101)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3319)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at org.eclipse.epf.rcp.ui.MainApplication.createWorkbenchAdviso r(MainApplication.java:116)
at org.eclipse.epf.rcp.ui.MainApplication.start(MainApplication .java:82)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
Previous Topic:Where begin
Next Topic:Error opening the editor - Error abriendo el Editor
Current Time: Sat May 18 17:47:18 EDT 2013
Powered by FUDForum. Page generated in 0.08230 seconds
