Home » Eclipse Projects » Java WorkFlow Tooling (JWT) » how can I handle project jars, that get loaded by my app dynamically
how can I handle project jars, that get loaded by my app dynamically [message #544531] Sat, 03 July 2010 08:14 Go to next message
geronimo013 is currently offline geronimo013
I'm using eclipse quite a while, but I did not found out (yet), how I can create a workflow for an eclipse project, that is a java library used by another eclipse project (the app).
No problem at all, if the app gets bound against that library.
But the app does not know nothing about that library but starts to load it at runtime from a defined directory.
How can I build an eclipse-project, that automatically updates a jarfile, so that runtime-loading will lead to the same result than sharing a project?
Lately I read about project facelets - would that be a way to go ahead?
Any hint is appreciated.
kind regards
Geronimo
Re: how can I handle project jars, that get loaded by my app dynamically [message #544773 is a reply to message #544531] Mon, 05 July 2010 09:34 Go to previous messageGo to next message
Marc Dutoo is currently offline Marc Dutoo
Member
Hi Geronimo
It seems to be a devtime/runtime classpath problem and not to have much
to do with JWT.
In your place, I'd use a build & packaging tool such as ant or maven to
assemble and produce my application runtime.
There are a lot of other solutions : e.g. if your runtime application is
a web application (.war) to be run in tomcat, you can use an Eclipse Web
Project. If it is an OSGi application, you've got specific build tools
as well.
Please look up further information in those places, ex. google up
"eclipse ant build".
Marc
geronimo013@gmx.de a écrit :
> Hello,
> sharing a project?
> kind regards
> Geronimo
Re: how can I handle project jars, that get loaded by my app dynamically [message #544789 is a reply to message #544773] Mon, 05 July 2010 10:15 Go to previous messageGo to next message
Hi Marc,
thank you for your attention!
to do with JWT.
In your place, I'd use a build & packaging tool such as ant ...
Looks like I was not able to express what I mean Sad
I already use a multi-project-build with ant, which works fine - same does my app.
I just wanted to know, whether there's a way to extend the incremental build capabilities of eclipse to handle a target jarfile too.
I know, that a jarfile can be exported from eclipse, but that's not an acceptable choice instead of a projects target.
I've no idea about what would be possible by extending eclipse - as til now I used eclipse just as an editor Wink
When I discovered project facelets, I thought: hey, may be some other guy had the same thoughts like me and he build an addon, so the projects target could be user defineable now ... Smile
kind regards
Geronimo
Re: how can I handle project jars, that get loaded by my app dynamically [message #544810 is a reply to message #544789] Mon, 05 July 2010 10:54 Go to previous messageGo to next message
Member
Hi Geronimo
> Hi Marc,
> Quote:
>> to do with JWT.
> Looks like I was not able to express what I mean :(
Looks like I'm not the right person and this is not the right place ;)
> does my app.
> now I used eclipse just as an editor ;)
> target could be user defineable now ... :)
Eclipse's incremental build capabilities are only there to serve its own
"build while coding" features. They've been extended ex. by maven
integration projects, but at some point that means that when you save
your java file it starts an mvn command, which is certainly not as light
as the default behaviour. That's all about compromise : either you want
something quick enough not to disturb you while you code, or powerful
enough to build any kind of runtime application.
> kind regards
> Geronimo
Re: how can I handle project jars, that get loaded by my app dynamically [message #544817 is a reply to message #544810] Mon, 05 July 2010 11:23 Go to previous message
Hi Marc,
any hint about a propper place?
integration projects,...
so the first sounds reasonable, but maven ... ? - not at all!
I never wonna get in touch with that stuff ...
something quick enough not to disturb you while you code ...
Quite sure and for 99% of the projects I was envolved that decision was right.
Just wondered whether I would be possible to trigger the jar-export automatically for certain project(s). I don't want to enable the jar-creation for any project!
kind regards
Geronimo
Previous Topic:Java Code Formatter as extension point - contribution
Next Topic:JWT Nodes palette
Current Time: Thu May 23 02:00:42 EDT 2013
Powered by FUDForum. Page generated in 0.01790 seconds
