| Re: Failed to load JNI shared library [message #545075 is a reply to message #544613] |
Tue, 06 July 2010 10:47   |
Eric Rizzo Messages: 2011 Registered: July 2009 |
On 7/4/10 6:28 PM, Guido Stein wrote:
> HI all,
> I am getting the following error message when I try to run
> explipse:Failed to load JNI shared library "Program Files
> (x86)\Java\jdk1.6.0_20\jre\bin\client\jvm.dll"
> I am trying to use the Eclipse Release 3.6.0 which was last revised June
> 2, 2010.
> I am running Vista home premium. I am running the exe as an admin. I
> have not put the eclipse folder into the program folder area.
> I added the following to my ini file
> -vm
> C:\Program Files (x86)\Java\jdk1.6.0_20\jre\bin
First, make sure that you're version of Eclipse and JDK match, either
both 64-bit or both 32-bit.
Second, the -vm argument in eclipse.ini must point to the java
executable, not just the directory. See
http://wiki.eclipse.org/Eclipse.ini for examples.
Hope this helps,
Eric
> My ini is as follow
> -startup
> plugins/org.eclipse.equinox.launcher_1.1.0.v20100507.jar
> --launcher.library
> plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1. 0.v20100503
> -product
> org.eclipse.epp.package.java.product
> --launcher.defaultAction
> openFile
> --launcher.XXMaxPermSize
> 256M
> -showsplash
> org.eclipse.platform
> -vm
> 256m
> openFile
> -vmargs
> -Dosgi.requiredJavaVersion=1.5
> -Xms40m
> -Xmx384m
> My computer return the following from "java -version"
> java version "1.6.0_20"
> Java(TM) SE Runtime Environment (build 1.6.0_20-b02)
> Java HotSpot(TM) Client VM (build 16.3-b01, mixed mode, sharing)
> Please let me know if you have any thoughts about how to resolve this.
| Re: Failed to load JNI shared library [message #559441 is a reply to message #545343] |
Thu, 16 September 2010 11:36   |
Hugh Messages: 4 Registered: December 2009 |
Junior Member |
I had exactly the same problem, the following error message:
| Quote: |
Failed to load the JNI shared library "C:\Program Files (x86)\Java\jre6\bin\client\jvm.dll".
and your previous posts helped me solve it, so thanks a lot!
I am running Windows 7, and I knew it was a 64-bit machine with the ability to run 32-bit apps, but I downloaded the 64-bit version of Eclipse.
Eclipse first said I had no version of Java; it wasn't true, but Java was not in the PATH. Still, not knowing any better I downloaded and installed the latest version of Java.
I finally figured out how to add Java to the PATH. Now, when I opened up a CMD prompt and typed Java, Windows was able to find it. Progress.
The error message from Eclipse changed from not finding Java at all to the one of this thread.
Hmmm. Much head scratching and reinstalling and I was stuck.
Problem was that I was trying to run the 64-bit version of Eclipse, and Javea was the 32-bit version, shown by the fact it was installed in the "C:\Program Files (x86)" directory and not in the "C:\Program Files\" directory.
I could not figure out how to get a 64-bit version of Java. Hmmm. Never mind. Instead downloaded the 32-bit version of Eclipse.
Now I have both Eclipse and Java as 32-bit and both work together great!!
So thanks for all your help!
I would say, it would be better if Eclipse could somehow detect that which version of Java is being run and give a more helpful message like:
| Quote: |
This is the 64-bit [32-bit] version of Eclipse, but the version of Java is 32-bit [64-bit] and the two are not compatible.
Either change the version of Eclipse or the version of Java to be compatible.
That would help people go straight to the solution.
| Re: Failed to load JNI shared library [message #1006769 is a reply to message #966810] |
Fri, 01 February 2013 13:26  |
Praba Prakash Messages: 1 Registered: February 2013 |
Junior Member |
This Is Common Issue
1.First Check Your Eclipse Is 64Bit Or 32 Bit.
2.Then Download 32Bit Or 64Bit JDK.
3.SET PATH:
Copy Link Locations:
for 64 Bit.:
C:\Program Files\Java\jdk1.7.0_05\bin
for 32 Bit.:
C:\Program Files (x86)\Java\jdk1.7.0_05\bin
4.Goto->System Properties->Advanced System Setting->Environmental variables->
New->
VARIABLE NAME .: PATH
VARIABLE VALUE .:C:\Program Files\Java\jdk1.7.0_05\bin
VARIABLE VALUE DEPENDING ON 32 or 64.
5.Important
32 Bit ECLIPSE -32 Bit Java SDK
64 Bit ECLIPSE -64 Bit Java SDK
6.ENJOY
FUDForum. Page generated in 0.10620 seconds
