Home » Language IDEs » Java Development Tools (JDT) » "create project from existing source" option("create project from existing source" option)
"create project from existing source" option [message #544575] Sun, 04 July 2010 03:02 Go to next message
lib is currently offline lib
Eclipse SDK
Version: 3.6.0
Build id: I20100608-0911
i'm new to eclipse and i downloaded a project to experiment with.
project instructions say to "create project from existing source" but with the version of eclipse i dl'd, i do not see that option.
just wondering if that option is from an older version?
how then to "create project from existing source" with ver 3.6.0 ?
tia
Re: "create project from existing source" option [message #544587 is a reply to message #544575] Sun, 04 July 2010 09:33 Go to previous messageGo to next message
Deepak Azad is currently offline Deepak Azad
On 7/4/2010 12:32 PM, lib wrote:
> Eclipse SDK
> Version: 3.6.0
Are you looking for File > Import > Existing projects into workspace?
Re: "create project from existing source" option [message #544614 is a reply to message #544587] Sun, 04 July 2010 19:15 Go to previous messageGo to next message
indeed, i do believe so. thx!
Re: "create project from existing source" option [message #544619 is a reply to message #544614] Sun, 04 July 2010 22:04 Go to previous messageGo to next message
yep, that worked for me. thanks for the help
Re: "create project from existing source" option [message #549783 is a reply to message #544575] Tue, 27 July 2010 19:02 Go to previous messageGo to next message
deti is currently offline deti
I have related problem:
- I have sources without any ant build file nor eclipse project.
- I need to add them to eclipse
- So, 'import -> existing projects into workspace' and 'new -> java project from existing ant build file' are not applicable for my situation.
As far as I remember "create project from existing source" worked exactly in the way I need. I just put way to source folder and got complete project with all of them...
The second way which I remember: add existed sources to existed project: But there is no option like this in project properties.
Re: "create project from existing source" option [message #549810 is a reply to message #549783] Wed, 28 July 2010 01:58 Go to previous messageGo to next message
Satyam Kandula is currently offline Satyam Kandula
Create a project and then do a File > Import > File System.
Re: "create project from existing source" option [message #649488 is a reply to message #549810] Wed, 19 January 2011 08:02 Go to previous messageGo to next message
VC  is currently offline VC
Create project using file>import and "create project from existing source" are two different things. File>import will just create a project and not java project.
Please let me know why Helios doesn't have this function - "create project from existing source" ?
Earlier ones had this. I have java project(not having ant file and its not an eclipse project) and I have to get this in eclipse. Please tell a solution.
PS: I wont create a new java project and then link existing source to this as this wont let me do CVS stuff directly from eclipse.
I need this URGENTLY. Please help
Re: "create project from existing source" option [message #649899 is a reply to message #649488] Thu, 20 January 2011 16:51 Go to previous messageGo to next message
No real name is currently offline No real name
Try File/New/Project
Select type of project, Next
Type in project name
uncheck default location
In Location edit box type in the path to your source
click Finish
Re: "create project from existing source" option [message #656930 is a reply to message #649488] Mon, 28 February 2011 22:11 Go to previous messageGo to next message
zhang  is currently offline zhang
I have the same question,why the latest version have that option,any function can do instead of it?
Re: "create project from existing source" option [message #656931 is a reply to message #656930] Mon, 28 February 2011 22:22 Go to previous messageGo to next message
that's right up, I should try first
Re: "create project from existing source" option [message #657503 is a reply to message #649899] Wed, 02 March 2011 21:58 Go to previous messageGo to next message
Dr Chan is currently offline Dr Chan
No Real Name wrote on Thu, 20 January 2011 16:51
click Finish
Thanks this worked for me
Re: "create project from existing source" option [message #658574 is a reply to message #544619] Tue, 08 March 2011 22:53 Go to previous message
David Southey is currently offline David Southey
Nice! Same here. it works for me too. thanks
Previous Topic:Using AST to parse my code with eclipse 3.2
Next Topic:Add code and text fragments at cursor
Current Time: Tue May 21 11:14:14 EDT 2013
Powered by FUDForum. Page generated in 0.01889 seconds
