| Re: Can't connect to ECF server [message #625275 is a reply to message #541677] |
Wed, 23 June 2010 12:18  |
Tom Messages: 6 Registered: June 2010 |
Junior Member |
I assume you red my post via a cell phone because I pasted an image of the error message.
and it is that URL, and I'd love to connect to my own instance of ECF, but that's a whole other problem: I'm running linux and there are only instructions for eclipse.exe for running a ECF server.
If you (or anyone else, don't be shy :d ) can guide me through on any of these problems I will very much appreciate it.
| Re: Can't connect to ECF server [message #625276 is a reply to message #542050] |
Thu, 24 June 2010 04:19  |
Markus Kuppe Messages: 177 Registered: July 2009 |
> the error message.
Odd, I don't see an image nor an indicator and I am using Thunderbird
with HTML activated. I assume you used http://eclipse.org/forums to post
your message and the nntp bridge cannot handle images.
Anyway, if possible please provide a text dump of the error, especially
what shows up in the "details" part of the dialog. But I just checked,
ecf.eclipse.org does not run the ECF generic server. The wiki has been
updated.
On Linux there exists also a binary launcher called "eclipse". That is
basically all you have to change when you want to run the server on Linux.
Markus
| Re: Can't connect to ECF server [message #625279 is a reply to message #542050] |
Sat, 26 June 2010 17:38  |
Scott Lewis Messages: 942 Registered: July 2009 |
Tom,
See the product configurations in this bundle
org.eclipse.ecf.server.generic
This bundle is located here in the source code repository:
server-side/bundles/org.eclipse.ecf.server.generic
OR if you've got the ECF Helios installed, you can import this plugin
directly into your workspace.
Within the bundle, there is a product configuration file:
products/Generic Server Equinox App.product
This product configuration will let you run/debug an ECF generic server
(on localhost or wherever you choose)...and you can also use it to build
and package (aka export) a platform-specific runnable. To do this you
may need to change the Generic Server Equinox App.product
configuration...i.e. to build/export properly for your platform.
Scott
> the error message.
FUDForum. Page generated in 0.02288 seconds
