| Minimal launch configuration [message #544341] |
Fri, 02 July 2010 08:29  |
Jonas Messages: 4 Registered: April 2010 |
Junior Member |
I've downloaded all needed AMP plugins into my Eclipse (Classic
Package). Now I'd like to create a launch configuration with the minimal
set of plugins needed to use AMP (build a model, simulate).
What is the minimal set of plugins needed?
Is there an easy answer to this question? Can I hit "Add required" in
the launch configuration editor as usual?
cheers,
Jonas
| Re: Minimal launch configuration [message #544494 is a reply to message #544341] |
Fri, 02 July 2010 17:47  |
Miles Parker Messages: 1266 Registered: July 2009 |
Hi Jonas, see below please..
| Jonas R wrote on Fri, 02 July 2010 08:29 | Hi,
Yea, you should be able to launch using "all workspace plugins". But its a great question so I added it to the http://www.eclipse.org/amp/developers/building.php page.
FUDForum. Page generated in 0.01721 seconds
