Home » Modeling » AMP » Development on AMP sources
Development on AMP sources [message #544340] Fri, 02 July 2010 08:18 Go to next message
Jonas   is currently offline Jonas
I'm trying to download all AMP and Ascape plugins as source code from
the CVS. I'm not sure if I'm missing something but it seem to be quite
time-consuming.
Isn't there a TeamProjectSet file I can import in Eclipse? This would
make it quite simple to get started. You could even integrate all needed
plugins into this file...
Jonas
Re: Development on AMP sources [message #544490 is a reply to message #544340] Fri, 02 July 2010 16:49 Go to previous message
Miles Parker is currently offline Miles Parker
Jonas R wrote on Fri, 02 July 2010 08:18
time-consuming.
Jonas
Hi Jonas,
There is indeed. See: http://www.eclipse.org/amp/developers/building.php
And I've just updated it. I don't know about the plugins part. I've actually just been mucking around with Buckminster trying to get a full materilization, but hopefully the updated docs and great new Eclipse install tools should get you on your way.
Let me know what's broken or if you have ideas to get it working better.
cheers,
Miles
Previous Topic:Problem with examples
Next Topic:Minimal launch configuration
Current Time: Tue May 28 07:51:41 EDT 2013
Powered by FUDForum. Page generated in 0.01799 seconds
