| IWAT0016E The Agent Controller is not available on host localhost [message #544211] |
Thu, 01 July 2010 23:08  |
xiaoru_hua Messages: 1 Registered: July 2009 |
Junior Member |
I am using tptp4.6.2.
In the dropins directory, there are following subfolders:
-birt-report
-tptp-platform
-tptp-test
-tptp-test-report
I want to use IAC to as the connection.
In the build.xml file,
I have tried following cases:
1. no tptp.test.connection
2. <property name="tptp.test.connection" value="tptp:iac://localhost:10002"/>
3. <property name="tptp.test.connection" value="tptp:iac://localhost"/>
4. <property name="tptp.test.connection" value="tptp:iac://localhost:10002/default"/>
5. <property name="tptp.test.connection" value="tptp:iac://localhost/default"/>
In WinXP, they works well,but in linux, none works.
This is the ant output:
[tptp:test] Launching delegate...
[tptp:test] org.eclipse.core.runtime.CoreException: IWAT4039E The Test Execution Harness reported the following problems: IWAT0016E The Agent Controller is not available on host localhost.
[tptp:test] Make sure that:
[tptp:test] * the Agent Controller is installed.
[tptp:test] * the Agent Controller is configured to communicate with your machine.
[tptp:test] * you have the correct host name and port number for the Agent Controller.
[tptp:test] at org.eclipse.hyades.test.core.launch.delegates.AbstractLaunch ConfigurationDelegate2.launch(AbstractLaunchConfigurationDel egate2.java:225)
[tptp:test] at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:853)
[tptp:test] at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:703)
[tptp:test] at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:696)
I just use a pure clean workspace without any manual configuration (no any changes of preference), and import two projects with testsuite.
| Re: IWAT0016E The Agent Controller is not available on host localhost [message #544710 is a reply to message #544211] |
Mon, 05 July 2010 06:23  |
Paul Slauenwhite Messages: 970 Registered: July 2009 |
This appears to be a firewall issue, blocking the Agent Controller's port.
If not, it is a new defect.
Paul
"xiaoru_hua" <huahuaxr@msn.com> wrote in message
news:i0jl82$75r$1@build.eclipse.org...
> -birt-report
> -tptp-platform
> -tptp-test
> -tptp-test-report
> 1. no tptp.test.connection 2. <property name="tptp.test.connection"
> machine.
> Controller.
> [tptp:test] at
> egate2.java:225)
> [tptp:test] at
> [tptp:test] at
> [tptp:test] at
FUDForum. Page generated in 0.01645 seconds
