Home » Eclipse Projects » ATF » ATF questions
ATF questions [message #543807] Wed, 30 June 2010 11:46 Go to next message
vlad.balan Missing name is currently offline vlad.balan Missing name
Member
i just installed ATF 0.3.0 on Helios for java ee developers. I have a few questions. I have a static web project, called "test-html" that i deploy on tomcat and access its index.html page as:
http://localhost/test-html/index.html
I created 2 debug configs
- a project file debug config
- a URL ATF debug config for this url.
A) I'm launching the project file debug config.
I see in the scripts view some text file versions of html and js files and, after a few tries, i understand that breakpoints must be set in these, not in the files in the project. What about the breakpoints set in the project files?
Aany way, in the text files, while the breakpoints in the index.html text version are hit, in the text version js files i cannot set breakpoints in the ruler. I have a screenshot but cannot attach it.
Is it work in progress?
B) I'm launching the URL ATF debug config for this url: http://localhost/test-html/index.html
I cannot debug in this case. Text file versions (Scripts view) are not available and breakpoints in the project files are not hit.
C)
Eclipse ATF doc is pointing at these links and everybody expects, but not finds, these features for static web projects:
Dojo Project Cycle Demo - speaks about "ATF project facet" and "Dojo/Rico Application" wizards
http://www.eclipse.org/atf/flash/index2.php
Using the Eclipse AJAX Toolkit Framework (ATF) - speaks also about the ATF facet, about "Dojo/Rico/Zimbra application" wizards.
http://live.eclipse.org/node/211
https://admin.adobe.acrobat.com/_a300965365/p56692696/?launc her=false&fcsContent=true&pbMode=normal
Create New Project - speaks about a wizard "Ajax Toolkit project" including a "Javascript Toolkit" to install, like Dojo and Rico.
http://www.eclipse.org/atf/flash/index7.php
Personality Builder Demo - speaks about a wizard "Ajax Tooling / Ajax Personality"
http://www.eclipse.org/atf/flash/index3.php
The bottom question is: what happen to these features? Are they still downloadable and usable? Where can we find them in order to install them in Helios?
Re: ATF questions [message #544030 is a reply to message #543807] Thu, 01 July 2010 08:18 Go to previous messageGo to next message
Member
for point A)
This morning i see that project file debug hits breakpoints in project files. Text file copies of these are not open anymore.
(see screenshots in bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=318491)
Re: ATF questions [message #544033 is a reply to message #544030] Thu, 01 July 2010 08:21 Go to previous message
Member
for point B) i'm attaching the eclipse error log entries, see the bug page
Re: ATF questions [message #563144 is a reply to message #543807] Thu, 01 July 2010 08:18 Go to previous message
Member
for point A)
Previous Topic:Re: ATF questions
Next Topic:ATF Debugging question
Current Time: Tue May 28 21:46:50 EDT 2013
Powered by FUDForum. Page generated in 0.01821 seconds
