Home » Eclipse Projects » Buckminster » qualifier replacement across projects
| qualifier replacement across projects [message #543726] |
Wed, 30 June 2010 08:29  |
Bernhard Merkle Messages: 88 Registered: July 2009 |
Member |
Hi again,
I have a java project A with a properties file version.properties and would like to use the contained values there for version identifieres for plugin B and C.
How can I achieve this in buckminster ?
Is ant task buckminster.versionQualifier the way to go ?
or is there a better way ? e.g. via the buckminster.properties ?
Is there a simple example how to use this ant task ? (e.g. I am unsure what ComponentName and ComponentType are.
thanks for your help,
Bernhard.
| Re: qualifier replacement across projects [message #543827 is a reply to message #543726] |
Wed, 30 June 2010 13:02   |
Henrik Lindberg Messages: 2427 Registered: July 2009 |
I don't really understand what you are trying to do.
Are the projects bundles, features, or just "plain" java projects?
What is it you want to build - a p2 site out of A, B and C. Or build
them independently (if so to what? just jars?), or to a site each, etc.
Typically a "relese engineering project" (releng) or "meta project" is
typically used where different properties files, queries, maps etc. for
different purposes are kept, with suitable names (dev, nightly, etc.).
When invoking commands in UI or headless just supply the properties file
from this project. (But you may have asked about something else...)
- henrik
On 6/30/10 2:29 PM, Bernhard Merkle wrote:
> Hi again,
> for plugin B and C.
> Bernhard.
| Re: qualifier replacement across projects [message #543848 is a reply to message #543827] |
Wed, 30 June 2010 14:46   |
Member |
--------------070301050904060301010601
Content-Type: text/plain; charset=UTF-8; format=flowed
Hi Henrik
i attached my current buckminster Project.
For sure there is room for improvement, e.g. atm we are not using a real
target platform but this is on my todo list.
Any other hints, corrections are very much appreciated.
I have a "normal" Java Project "CodeGen". This will be delivered as
normal jar and as a eclipse plugin. I want to create the feature and
update site automatically with buckminster for the "CodeGen" plugin.
In "CodeGen" there is a version.properties file with system properties
(3 numbers). I want to use them and produce the corresponding "feature"
and "site" project with the correpsonding version number.
How can I do this ?
"de.sick.sopas.generator.srt.buckminster" is my feature project and
contains most of the buckminster configuration. Can you have a look at
that ?
"de.sick.sopas.generator.srt.site" contains the update site project.
I invoke this in the Eclipse IDE via the buckminster menu for the
"d.s.s.g.srt.buckminster" and the for "d.s.s.g.srt.site". action
p2.site. The producted update site seem fine and the plugin is signed.
I want to invoke this however via hudson/buckminster of course.
This does not really work (2 problems pls see below)...
My commands are:
importtargetdefinition -A
'${WORKSPACE}/de.sick.sopas.generator.srt.buckminster/de.sic k.sopas.generator.srt.target'
import '${WORKSPACE}/de.sick.sopas.generator.srt.buckminster/site.c query'
build
perform -D target.os=* -D target.ws=* -D target.arch=* -D
qualifier.replacement.*=${version}
de.sick.sopas.generator.srt.feature#site.p2
however as in the previous post i have two problems:
- the source plugin is still build.
- the plugin is not signed.
I just updated/reinstalled the bm 3.6 headless in a fresh directory and
the behaviour remains the same so I am really stuck here.
okay. I assume I can look up the buckminster or b3 project for a verbose
example under the releng project, right ? (or which other eclipse
projects ?)
thanks so much,
Bernhard.
> Regards
> - henrik
>> Hi again,
>> for plugin B and C.
>> Bernhard.
Content-Type: application/octet-stream;
name="buckminsterProject.zip"
Content-Disposition: attachment;
filename="buckminsterProject.zip"
UEsDBBQACAAIAIJ+3jwAAAAAAAAAAAAAAAAwAAAAZGUuc2ljay5zb3Bhcy5n ZW5lcmF0b3Iu
c3J0LmJ1Y2ttaW5zdGVyLy5wcm9qZWN0dZDNjgIhEITPmvgOZu6C3jzgmKjx 6EV9AGQ6E3aG
n3QzxscXEN0dk70Qvkp1V4HYPkw/vwOSdnZTrdiymoNVrtG23VTXy3Gxrrb1 bCo8uh9Q4QCk
UPsQ3VGdCCsN1A0w0qpj5Lwk1oIFlMEhIwzsNqjOaEsBUPDsTmPKGQM21IK/ b0ktGZSBj+g2
6L45e1CJCu7jqLRNVkoThy0D1WtPwHysdQQZBoRdsv8tEP0S2yElU2E+FgT/ zijKu0QMTKuL
+wX/5Z/ymeKzKy/7Hf88dfy5T1BLBwj9r3Gi0wAAAJsBAABQSwMEFAAIAAgA gn7ePAAAAAAA
AAAAAAAAADkAAABkZS5zaWNrLnNvcGFzLmdlbmVyYXRvci5zcnQuYnVja21p bnN0ZXIvYnVj
a21pbnN0ZXIuY3NwZXjFVMtu2zAQPDtA/4Egcg3Z9FQEUnIomiC3Amk/gKI2 NmGJZMllHDfw
v5cP2ZYNq0mRQy4CXzM73BmxunnuO/IEziuja3rJPlMCWppW6XlNf/28vfhK b64/nVXSW5Df
nxF0OkkiSvsrafqaLhDtFeer1YqB7JT1wIyb8ybIZa+0R3D8m+l7oy8ye0a+ DfUQS2ZQFDCr
hMRY2afxrLKh6ZQkWvRQU+lAIDDrTBskUhJPGldToTEjZxlr3A9nLDhUUDgS S1lZkyWsa9oE
1bW3qgNKnkQXYFjhAy9LfISfxqJwc0C/Qx5LGmAVP6lkSzYpLc4ex8IejBX+ DjQ4UejK7oQ4
FXbAFphXcsl8ImDzLQMDPKH1WFWkBQe/g/IKwRPRKRGddGBNXDBuTbflBaJT TUAYDErnmf1y
QD1i2jchCdgRt+BRaZFcp6QRPhKdv4wCwkxAG3CzK2sFLkj6/POe5y/FLLby m/3EjCfCycWG
H3YiSyvh4yV9ryaR/VH2/Wm8b0d53F/etoDCL/3/RjJrejWOJ3wu/x/LGw56 0JF7yvDJ+L/F
96FQcfcjnD/q0aT5uX3Dm1Txwxfy+i9QSwcIMxXeSrkBAABaBQAAUEsDBBQA CAAIAPqj3jwA
AAAAAAAAAAAAAAA+AAAAZGUuc2ljay5zb3Bhcy5nZW5lcmF0b3Iuc3J0LmJ1 Y2ttaW5zdGVy
L2J1Y2ttaW5zdGVyLnByb3BlcnRpZXN1kb1qAzEQhPuDe4cFpwqxBCkNVxhS hDQJduEyyLq1
b7FOUrQrGxPy7tGdf8DE6Vajj5nRagKv4QDqKxtHG8IE5GGPiSl4Bu5Cdi2s ERJGZyy2dXUl
1Vnr0Yt6bLboMRkJaeYMywL3NHjUVV1NYNVhQjDOgXQIIUvMAk8g2EfYkMNL 0DYM9DrbXU+e
pWScWJVCkKYTiTOtD4YPZkeKye6sVx5F25BiKOFIXpIZlIV/0cv3j/lSc4iG p5xkem04zbEt
8JRJUNfVf3kP35mL1IUef3R8HuhbeOh/B5U+nnFVxtMGXtBRWSswbT228DZf jA/nunLBGqd2
eOTSDFU00kEDq5m+SLo/XsY/dPkKwwVH6ygyfg47uWPJfAipLRyjTSh1NZYb upDfFllSxkEc
z0qOEYs4uty29wE45GTxUt6uSZG3LrfF7nTTwMY4xl9QSwcItAu6OE0BAABY AgAAUEsDBBQA
CAAIAIJ+3jwAAAAAAAAAAAAAAAA4AAAAZGUuc2ljay5zb3Bhcy5nZW5lcmF0 b3Iuc3J0LmJ1
Y2ttaW5zdGVyL2J1aWxkLnByb3BlcnRpZXPFjksKwkAQRPeB3CEHkJ5JFH/g TQTpTDpxdH50
TzTHN7hVd6K1LIp6r7UBbDBu7EiqQ9UT5pEJJu/KoiwuyAI0ZUYwDkUS5vO8 Sg5zH9nvVXLj
YIPqCMSaK0hMKDBQIMYcGYSzcrYVNX+oKWHoVOQByDibhIB8D/5OYCLTScMG Grg1Wu/0tm70
qt7AzF8cy6J6n29rjNk6+aPHs3nlL9e/4mf6zC+LB1BLBwh44C1CpwAAACsC AABQSwMEFAAI
AAgAgn7ePAAAAAAAAAAAAAAAAEoAAABkZS5zaWNrLnNvcGFzLmdlbmVyYXRv ci5zcnQuYnVj
a21pbnN0ZXIvZGUuc2ljay5zb3Bhcy5nZW5lcmF0b3Iuc3J0LnRhcmdldF2Q T0vEMBDF74Lf
IeTeZu26yyJpi1j14FEFDwWJydAGkklJY9v99qZZ8c+e8t6beT+G8Hqxhkzg R+2wpFf5hhJA
6ZTGrqSvLw/ZgZIxCFTCOISSoqN1dXnB60HBb2+b71IcB0H4DgJBYeP2nVPw CJifQroWjZMi
xNL415BBhD6u37RaQas/bAvS6GGE7Ll5yiI9L7JZ47agJByHCG60BxmcP1K2 ctg/KuCkvUML
GFbrxip1OXNpPP/4OXnhZV8thz1nScUETaXgvbnnLKoVf0Y04hNlD/7Wd4kw 2aSyNztebyyJ
71Ls9paz70G68KzDTn8S5RdQSwcIRLCMrfQAAACEAQAAUEsDBBQACAAIAIJ+ 3jwAAAAAAAAA
AAAAAABPAAAAZGUuc2ljay5zb3Bhcy5nZW5lcmF0b3Iuc3J0LmJ1Y2ttaW5z dGVyL2RlLnNp
Y2suc29wYXMuZ2VuZXJhdG9yLnNydC50YXJnZXQuc2F2ZcVb34/bNgx+H7D/ IQj2WiV3/bFr
cblixbphDwUKrMUeC8VmHOVkyZPkJIdh//soOU7iXGNROR/20PZykSmK/Eh+ pNXb99tSjtZg
rNBqNr5i0/EIVKZzoYrZ+OuX317cjEfWcZVzqRXMxkqP39/9+MPt+yqHw3Mv 2evwa/zCcVOA
Gyle4uo/dcXt6HdQYLjTZvQlfDn2AqTOuMOH7fGHUcXdcjb+6R/IpKgsfFvq Ev4dj9xDhdI+
G70QEsLjQmWyzuFDrXIJQUYl60KokchnY20KVmrj5vyBrcC5B2bBoLLjyXcW 7rZi8HctlN6y
TJelVr1LtS1EECkysMzq2mTQ+0AtmFDOaOJaxdei8AaLLewRt6qVcKQDV9es BMdz7njv+tWC
Z8D8srlQHiCU00C2YN5pznBlF2dcwCueLYHJOkOk9OuQOyZ5rbIldf/DIblx Ao/gmIFKW4Hm
fYg6LYeUTXhVkZaXC/xZG2DZkquCtgU+U268UjGdN0K9vKaIDBp438zrBXrm LJAxIJiY45+s
7vPeitsqFmIIhsroNZrVdFDBrJV9spuYtEzqAr8tYiZYaFOS4rJxglYOlPM5 hgYlA6gyZkla
7O/NbB+sgzI1BRDXB6/HFkHuUW+Jy4g7B2OTsOstETeVgWZf0v4+H0RCIghV 4PrEceWkYaZW
TpTxOGzQSFWPGNyEstMC0EAhrItkr8aWzYm8cKysYi6kwGLIa7ckbWRFWUnM VGohitpQ0RjS
G0KIsjbH5FMQkhpsHRjFpdNa9gJjlzDQoSmqUnIPPhI3+HF11HNPEfhcxjFC NcNGm/s5Zp4l
MTY7ZrsULiS4dQozrfoRKFb8kNsKuWnMcl45fyZMwoZ5W1ApQ7BKHG0tREBS s3Xrx96FHsQx
DU6VXjpXNZw3DaxYlrF6e6ZMrGipPPBg1BU3uBsmeBsnuMgUkuhlgrN2XIKa xjv4oTwk3X1b
0Dzr1CYWGCHqDJBd3skHzod6qNvRk4TOgFzsjokq1cNEgv1IGcqplyCrWLz3 1K+SK1HVMlbL
Oh0JBiKXD1YQMuiB5/WutZv+1mzHS0vUNifsesRgE2OxbfyOXEaEHpqHO7sE cP0K4lF3LUnz
9/bmDbVvxOBHWEQymV+I3UPKuReGl+BDh+elUAe0xCX4qkRPw778Y2qiBH0c 8nNuKaXoBLFP
b5FpcIjWMUKFblIBYTsHvIwKDMMKIpSxHOgIS2trMRm0fXt/bzZFDYqz/TNV QHJ4n3tixdd8
2wvyzmTgSQfsG0qQKniAgy+Sl7Ts+8xFrt8JbS4tLujzAppgz07wsSNuQou8 bfJMkWxw2Fao
ux8op6at71QxGj+ArDY+VqkO7m2pk5Q+zJCSNI3BYC1gY1syL8AyJOlzyBPt GUVwhxDzikBm
VtgNn59TP6F6U4M/bbRNHffG61S8aHTeOwwzpWr8k9i7prN7Yi05A0raCfaE XUSmY4QJxmWN
NDmBHSaX3e3JczBS3IWlJJNfmAPpzKV24izt6LADtrKkNyMWuOkfbj1WIFqw yP7zQ2JaJWj0
pMORNmMgjwmprcr+HeWlg8uEhpxM3MkTrXJBDBnqpJd6GN9qEdlk/2wSm/Lo bPL8rCKJMUUH
af71M0mRpGSZ9fvoMEDaliSEpCD8JOfSIvfQ7lHhkEijk2eCT59cUAs3KFxA TUZEJ5wZQpJG
9yE87BJ7pmiUnOYoUjKP16Q+YoRsK3WwdUGTdtG8vR3W05rY3ev9uC8i9kq6 2YDxTqOFRDQ2
iSFhus8pIFlzI3ydo1GlbvQNMIFO6rFoSGlGEJe/kHkq2U3jnNSKnHAetDUK x9Y6Upv9e0Na
20o3CeWVymk6Th4nJ0xIyZrv44D+NuykNSNPH89c9OnOitNyDf2iT/NCJeWQ zaLJ4+uGk/bO
ov+wv7+4W/eLlJ/RLuFqzGy84BIJZfvdJ53DbFxhglJg2quNfyjruJTeB1/9 tM8L9YORR3pV
O7HhzWjnAia7Yp+up9O307dXP7+Y3kynjer9Umx+f7kUfJisxmFoMGqNhYbB 3PZu8te7yYc6
u8eUah2Yib9yJ7L7g67Xk3ktZM4+Nr/APSY7r/w/LjgAbwHc1fhvYXRdHZnh Gs0wZetghjdX
r6+mr172mNHLG06Sd8pw0jK0VAHqGST6m2Nnhb5KFhpmZ0NqGQT2Kpkq85jB nZN6heGTKFVn
z+CdofHdlTuoWRuR4cLZcEJLXlXeT0PboSt31ysNaIthrXCM2F7R6bAN4obF wZZ7rm2fQ2RD
GJ4BB8NLHNSmSKbxaQeDYvR5oD+4i5ALDCRta/MBJQ1X4L204cqHlwbtdaRB URMkD5fZvLhh
4+9Y4qDAbk8+qMBLI+XZKfyk83/CQK2F0arETt5/1PYuzNluJzp8vdl/3oTP /oXM3fbmze0k
/IS/UfIuh2+/fryd4E9e/InESfNf1fDH/wBQSwcIbRYNeSQHAAAGNwAAUEsD BBQACAAIAIJ+
3jwAAAAAAAAAAAAAAAAzAAAAZGUuc2ljay5zb3Bhcy5nZW5lcmF0b3Iuc3J0 LmJ1Y2ttaW5z
dGVyL2ZlYXR1cmUueG1shZLBT8MgGMXvS/Y/NNwL82ZMu8U49WKi2ebJeED4 2pExQKB2+tfL
WoZdnLM9Ae97v9fyitluK7MPsE5oVaILPEEZKKa5UHWJnld3+SWaTcejogLq GwvjUdY9gpeI
A3aCbbDThjpcgwJLvbbYWY+jHB30kr6BLNHy8el6mS0Xq+z+IE+SYYjwvjdU ikqARQHfaQoO
jllhfFBljQ12a+/NFSFt22LY0a2RgJnekoFuP9zbn0D3rkN5QjFtPq2o1/4s KKl+MC+3yoPN
btL8fBB6DRbwa8Sm4QSVgoFycBYZNb+AD3H2T1wcTLAASR5FYzj1cO6WjkNR 19KN6K6fKazA
h6+xRgcpCOUt3e8s1Jx0TqQrSB5qkaeS5D0xd8IDQWQaQ/ah+oWRTS3UIeL/ nUMDKdetkpry
4P8FJZoMz4Rynkp56ihVcF/Ao5NGGco2JaqoDD+fdCELElseVt9QSwcIqEp8 uVsBAABIAwAA
UEsDBBQACAAIAEqA3jwAAAAAAAAAAAAAAAAzAAAAZGUuc2ljay5zb3Bhcy5n ZW5lcmF0b3Iu
c3J0LmJ1Y2ttaW5zdGVyL3NpdGUuY3F1ZXJ5ZY89TgMxEIV7JO5gTR87dGgV kyJSOgpQOIDj
DIuV2OOdGbPk9ngjhYZXPul7P5vtT76Yb2RJVDw82TUYLJFOqYwePg771TNs Xx4fNnEaIuVK
BYu+NeSr6WCRIU4evlTr4Nw8zxbjJVVBSzy6Y4vnnIoostvdmNUtn1GoccTX UD1IUrScQ4Xe
YrqWJibSd5waipoSMno4oZUUz1aoBrEjFuSgxFZY7RIB5m/d4Vo7cB/yiUEb I7jlhPv3oru/
UEsHCKQfEWy9AAAAAwEAAFBLAwQUAAgACACZgN48AAAAAAAAAAAAAAAAMQAA AGRlLnNpY2su
c29wYXMuZ2VuZXJhdG9yLnNydC5idWNrbWluc3Rlci9zaXRlLnJtYXDNVU1r 3DAQvRf6H4RO
La01bUKhmLh7SOmlFEqa0IsJyPJ4V6z1wUiOd/99ZTubOLBbNu1SejHGfvPe vKcZdLHYmJbd
IQXtbMHfi3ecoVWu1nZZ8JvrL9lHvvj08sUFmZyM9CzBbcgrVfBVjD4H6Pte oGq1DygcLaHq
1NpoGyISXDpjnM1G1qmQzFGFV9+kH8uSNGODeOuUjI6YlzEBUqu3NZZCRzQ6 lGITcRNflUK8
eb3gLKAktfou4+oKm4JPIA6/4Ur6pZA2tvS3JPeOTtTSnM3Wp2Pz8oRsaJpS mB4PEaZfR4Tv
pVolMjWOTPhTrmEoglbr9HReHqQhDK4jhftsHgF9hDArDT5kNgImiCd3p2sk lgx5Z9HG663H
UHAXllpUna1bfLsb/wZl7Ag5I5SpZkAWfOinTZ2P6gVvZBtwp7BT6UizxqXF jAmgW8zhMock
C7oycM+e/fj8NTsXH8RZ1mt7fgZzkkRTqaFZjxS3yTBb47bgs10UDwY4g7k8 TPo7zzAzPQUF
T5I6HN5wpv8wuf25wVHJwXPc7jX7OE7/geWfOUQMEXpH65AWEJ/ncPwy3Arp /RdQSwcItVL7
urYBAABJBgAAUEsDBBQACAAIAIJ+3jwAAAAAAAAAAAAAAAAwAAAAZGUuc2lj ay5zb3Bhcy5n
ZW5lcmF0b3Iuc3J0LmJ1Y2ttaW5zdGVyL3NpdGUueG1sjZJNT8QgEIbvJv4H wh1Gb8a0bkzM
etRs17NBOq3sdqECdfXfO21Zt8a1EQ5kYD6eeZls8bFr2Dv6YJzN+aW84Ayt dqWxdc6f1ktx
xRc352dZMBHpZIxlJQbtTRspglm1w5wXD4+3BStWa3aPFr2KznPW+SbnrzG2 1wB7FfZqa2Qw
equttBhBO986ckVjo1f9zcrewZAJgmtVEMFHUR/yia4tyVn0HMBHElonKo+Q MKFM3BWq2Hkc
wZIRyG+gkkNN+V1PUnWZnJ5JFtpvnWpMZdDLjaL+TJnzfwTzH+pO0xy7yDS1 Vjv/OaMnpC4g
5U3mIVKUWM39RqNesDn9dsT4pdm8yH/oDFOmfnYgDc8XUEsHCJ6d0PoOAQAA bQIAAFBLAwQU
AAgACACCft48AAAAAAAAAAAAAAAAOgAAAGRlLnNpY2suc29wYXMuZ2VuZXJh dG9yLnNydC5i
dWNrbWluc3Rlci90ZWFtcHJvamVjdHNldC5wc2btl8uOmzAUhveV+g4RazDG 3MtkZlGpfYF2
PTq2DwkNN9km6ePXkKYZtRMyVSJ1URZYtv/fPub7JS4PT9+berVHpauuXTsB oc4KW9HJqt2s
na9fPnmZ8/T4/t1Dr8uzjVnbNKm6fSVRrSq5djq1ISjqqtdIDEJD9L4lolM4 dlowg8LTom8o
zEphicrWwqksCdytMb3+4PsSYaMppQn17crxegZ98HXXg/bt0XCDrW/U0O7c j3b0GVs3pjQI
U5pDKFLbxQBsA5KiwChFxov5va/JXEErtqgLY+ViKj22WMSR4DkK4YFMmBfm EfUykYAXyIxm
vMzTmMO1zYsSao1FUTDm+DcAej50asetf3uEY21EV2JHJnDEQkMFplNEK0NK nAJx3+IBipCI
UIhMhBNcLtKSsTThZcJ4EFy5wfO53m68CFzmaZphHnkljZnHMAo8zrPMS9I4 T5NABBSuhf2i
zD9BP/QSzKibefwvfUsEN0YwSElAQm9QuZeVBfMdMGNTvoJ4nF3w3oj3gFyj sq9hcqheA/2n
viC/K/JfT+hZ8GfXgv+u+Bv7uVfPoj86Fux3xT5Us8ytvAC/FfhJJRqavsaf VfTv4C/ZlgBu
DODvgP9PvP3TX/5xoMvHH1BLBwjoqW0Q2QEAADUQAABQSwMEFAAIAAgAWH7e PAAAAAAAAAAA
AAAAACkAAABkZS5zaWNrLnNvcGFzLmdlbmVyYXRvci5zcnQuc2l0ZS8ucHJv amVjdHWQwQ7C
IBBEz5r4D6Z3QW8esCZqPHpRPwDppkFbILvU+PkCUpuaeCHM8NgZENtX28yf gKSt2RQrtizm
YJSttKk3xfVyXKyLbTmbCof2DsofgBRq5wMd3IkwsoWyAkZaPRhZJ4nVYACl t8gIfTjwIHjC
Iq9s24LxpeD9Lrp5OCXBR+rW6aY6O1BRZbkPV6WpkpMrWKwZqEY7AuZCnyNI 3yHsIg44FAi8
xLqLyZQ1HxuC/2Zkpy8RAuPoTH/Ev/xTWmN8otKw4fr3qeNffQNQSwcIuHJr p80AAACUAQAA
UEsDBBQACAAIAACk3jwAAAAAAAAAAAAAAAA3AAAAZGUuc2ljay5zb3Bhcy5n ZW5lcmF0b3Iu
c3J0LnNpdGUvYnVja21pbnN0ZXIucHJvcGVydGllc3WRvWoDMRCE+4N7hwWn CrEEKQ1XGFKE
NAl24TLIurVvsU5StCsbE/Lu0Z1/wMTpVqOPmdFqAq/hAOorG0cbwgTkYY+J KXgG7kJ2LawR
EkZnLLZ1dSXVWevRi3pstugxGQlp5gzLAvc0eNRVXU1g1WFCMM6BdAghS8wC TyDYR9iQw0vQ
Ngz0OttdT56lZJxYlUKQphOJM60Phg9mR4rJ7qxXHkXbkGIo4UhekhmUhX/R y/eP+VJziIan
nGR6bTjNsS3wlElQ19V/eQ/fmYvUhR5/dHwe6Ft46H8HlT6ecVXG0wZe0FFZ KzBtPbbwNl+M
D+e6csEap3Z45NIMVTTSQQOrmb5Iuj9exj90+QrDBUfrKDJ+Dju5Y8l8CKkt HKNNKHU1lhu6
kN8WWVLGQRzPSo4Rizi63Lb3ATjkZPFS3q5Jkbcut8XudNPAxjjGX1BLBwi0 C7o4TQEAAFgC
AABQSwMEFAAIAAgAWH7ePAAAAAAAAAAAAAAAADEAAABkZS5zaWNrLnNvcGFz LmdlbmVyYXRv
ci5zcnQuc2l0ZS9idWlsZC5wcm9wZXJ0aWVznY5LCsJAEET3gdyhwW3oG2Qh LlwqxgtMZtrY
OJ/QPYF4eyOMMMvg+lW9qpEjcrR+caTQw4NMXoRwDb5t2uYAJ5NpSvIGR9Yb MZlT7CBQGEn0
yXO3AbXC8xe0jS1xZIeOUNm+UNNsFCeKtNWToErGstMPl+txgOF2h/OPV5Iy s8u0I1OZq9P/
//wAUEsHCGDiON6KAAAAPAEAAFBLAwQUAAgACABYft48AAAAAAAAAAAAAAAA LAAAAGRlLnNp
Y2suc29wYXMuZ2VuZXJhdG9yLnNydC5zaXRlL2ZlYXR1cmUueG1sjZJBS8Mw GIbvg/2HkLvp
vIm0DlHnRVDsPImHmH5rg2lSv6R2/nuzNg2BsWF6Cn3e9+nH13y9bxX5AbTS 6IJeshUloIWp
pK4L+rbdXFzR9c1yke+Aux5huSDjkVVBK2BWii9mTcctq0EDcmeQWXT+hQM6 w4p/gipo+fxy
W5LydUseZzYi6Rf457vnSu4kIPXukckrsAJl5zxFevR1jXPddZYNw8Bgz9tO AROmzRLuEJ7q
3x+0AySbaQhyn3Q1gMA+JkcajmJhul+UdePOaiN1JL2L+ZPaGI5SJQVoC2eV gTkSPoXsSV0I
RpnUQvV+9LnnH/sNvwNNInGFhwWuaDbW51kg/e0PUEsHCEF+KWoFAQAAbAIA AFBLAQIUABQA
CAAIAIJ+3jz9r3Gi0wAAAJsBAAAwAAAAAAAAAAAAAAAAAAAAAABkZS5zaWNr LnNvcGFzLmdl
bmVyYXRvci5zcnQuYnVja21pbnN0ZXIvLnByb2plY3RQSwECFAAUAAgACACC ft48MxXeSrkB
AABaBQAAOQAAAAAAAAAAAAAAAAAxAQAAZGUuc2ljay5zb3Bhcy5nZW5lcmF0 b3Iuc3J0LmJ1
Y2ttaW5zdGVyL2J1Y2ttaW5zdGVyLmNzcGV4UEsBAhQAFAAIAAgA+qPePLQL ujhNAQAAWAIA
AD4AAAAAAAAAAAAAAAAAUQMAAGRlLnNpY2suc29wYXMuZ2VuZXJhdG9yLnNy dC5idWNrbWlu
c3Rlci9idWNrbWluc3Rlci5wcm9wZXJ0aWVzUEsBAhQAFAAIAAgAgn7ePHjg LUKnAAAAKwIA
ADgAAAAAAAAAAAAAAAAACgUAAGRlLnNpY2suc29wYXMuZ2VuZXJhdG9yLnNy dC5idWNrbWlu
c3Rlci9idWlsZC5wcm9wZXJ0aWVzUEsBAhQAFAAIAAgAgn7ePESwjK30AAAA hAEAAEoAAAAA
AAAAAAAAAAAAFwYAAGRlLnNpY2suc29wYXMuZ2VuZXJhdG9yLnNydC5idWNr bWluc3Rlci9k
ZS5zaWNrLnNvcGFzLmdlbmVyYXRvci5zcnQudGFyZ2V0UEsBAhQAFAAIAAgA gn7ePG0WDXkk
BwAABjcAAE8AAAAAAAAAAAAAAAAAgwcAAGRlLnNpY2suc29wYXMuZ2VuZXJh dG9yLnNydC5i
dWNrbWluc3Rlci9kZS5zaWNrLnNvcGFzLmdlbmVyYXRvci5zcnQudGFyZ2V0 LnNhdmVQSwEC
FAAUAAgACACCft48qEp8uVsBAABIAwAAMwAAAAAAAAAAAAAAAAAkDwAAZGUu c2ljay5zb3Bh
cy5nZW5lcmF0b3Iuc3J0LmJ1Y2ttaW5zdGVyL2ZlYXR1cmUueG1sUEsBAhQA FAAIAAgASoDe
PKQfEWy9AAAAAwEAADMAAAAAAAAAAAAAAAAA4BAAAGRlLnNpY2suc29wYXMu Z2VuZXJhdG9y
LnNydC5idWNrbWluc3Rlci9zaXRlLmNxdWVyeVBLAQIUABQACAAIAJmA3jy1 Uvu6tgEAAEkG
AAAxAAAAAAAAAAAAAAAAAP4RAABkZS5zaWNrLnNvcGFzLmdlbmVyYXRvci5z cnQuYnVja21p
bnN0ZXIvc2l0ZS5ybWFwUEsBAhQAFAAIAAgAgn7ePJ6d0PoOAQAAbQIAADAA AAAAAAAAAAAA
AAAAExQAAGRlLnNpY2suc29wYXMuZ2VuZXJhdG9yLnNydC5idWNrbWluc3Rl ci9zaXRlLnht
bFBLAQIUABQACAAIAIJ+3jzoqW0Q2QEAADUQAAA6AAAAAAAAAAAAAAAAAH8V AABkZS5zaWNr
LnNvcGFzLmdlbmVyYXRvci5zcnQuYnVja21pbnN0ZXIvdGVhbXByb2plY3Rz ZXQucHNmUEsB
AhQAFAAIAAgAWH7ePLhya6fNAAAAlAEAACkAAAAAAAAAAAAAAAAAwBcAAGRl LnNpY2suc29w
YXMuZ2VuZXJhdG9yLnNydC5zaXRlLy5wcm9qZWN0UEsBAhQAFAAIAAgAAKTe PLQLujhNAQAA
WAIAADcAAAAAAAAAAAAAAAAA5BgAAGRlLnNpY2suc29wYXMuZ2VuZXJhdG9y LnNydC5zaXRl
L2J1Y2ttaW5zdGVyLnByb3BlcnRpZXNQSwECFAAUAAgACABYft48YOI43ooA AAA8AQAAMQAA
AAAAAAAAAAAAAACWGgAAZGUuc2ljay5zb3Bhcy5nZW5lcmF0b3Iuc3J0LnNp dGUvYnVpbGQu
cHJvcGVydGllc1BLAQIUABQACAAIAFh+3jxBfilqBQEAAGwCAAAsAAAAAAAA AAAAAAAAAH8b
AABkZS5zaWNrLnNvcGFzLmdlbmVyYXRvci5zcnQuc2l0ZS9mZWF0dXJlLnht bFBLBQYAAAAA
DwAPAOgFAADeHAAAAAA=
--------------070301050904060301010601--
| Re: qualifier replacement across projects [message #543942 is a reply to message #543848] |
Thu, 01 July 2010 03:29  |
Thomas Hallgren Messages: 3163 Registered: July 2009 |
Hi Bernhard,
Looking at the perform command, I don't see that you pass any properties
to turn off the source build or control signing. Shouldn't there be a -P
<some folder>/buckminster.properties somewhere?
- thomas
On 06/30/2010 08:46 PM, Bernhard Merkle wrote:
> Hi Henrik
> How can I do this ?
> that ?
> My commands are:
> build
> projects ?)
> thanks so much,
> Bernhard.
>> Regards
>> - henrik
>>> Hi again,
>>> for plugin B and C.
>>> Bernhard.
Current Time: Tue May 21 02:33:50 EDT 2013
Powered by FUDForum. Page generated in 0.01877 seconds
