| "Property marker value too long" exception during build [message #543040] |
Mon, 28 June 2010 05:29  |
Sean Hodges Messages: 4 Registered: June 2010 |
Junior Member |
Has anyone seen this error? I started getting last week, it occurs during a build, and causes the build to fail. I've provided the full stack trace at the bottom of this post.
I suspect I'm getting a build failure in my project; and AJDT is throwing an internal error when trying to log/display it because the classpath is too large...
The project itself is not especially large, but it does have around 120 dependencies for Spring, Hibernate, CXF, etc.
I'm not sure what to do from here, beyond uninstalling AJDT completely. Any ideas for work-arounds?
org.eclipse.core.runtime.AssertionFailedException: assertion failed: Marker property value is too long: Building with settings:
-> output paths: /home/sean/Documents/MarketPlace/src/target/classes, /home/sean/Documents/MarketPlace/src/target/test-classes
-> classpath: /home/sean/Documents/MarketPlace/src/target/test-classes:/home/sean/Documents/MarketPlace/src/target/classes:/home/sean/.m2/repository/javax/activation/activation/1.1.1/activation-1.1.1.jar:/home/sean/.m2/repository/javax/persistence/com.springsource.javax.persistence/1.0.0/com.springsource.javax.persistence-1.0.0.jar:/home/sean/.m2/repository/javax/servlet/com.springsource.javax.servlet/2.5.0/com.springsource.javax.servlet-2.5.0.jar:/home/sean/.m2/repository/javax/servlet/com.springsource.javax.servlet.jsp.jstl/1.2.0/com.springsource.javax.servlet.jsp.jstl-1.2.0.jar:/home/sean/.m2/repository/javax/transaction/com.springsource.javax.transaction/1.1.0/com.springsource.javax.transaction-1.1.0.jar:/home/sean/.m2/repository/javax/validation/com.springsource.javax.validation/1.0.0.GA/com.springsource.javax.validation-1.0.0.GA.jar:/home/sean/.m2/repository/javax/xml/bind/jaxb-api/2.1/jaxb-api-2.1.jar:/home/sean/.m2/repository/javax/transaction/jta/1.1/jta-1.1.jar:/home/sean/.m2/repository/javax/mail/mail/1.4.1/mail-1.4.1.jar:/home/sean/.m2/repository/javax/xml/soap/saaj-api/1.3/saaj-api-1.3.jar:/home/sean/.m2/repository/javax/xml/stream/stax-api/1.0-2/stax-api-1.0-2.jar:/home/sean/.m2/repository/antlr/antlr/2.7.6/antlr-2.7.6.jar:/home/sean/.m2/repository/asm/asm/2.2.3/asm-2.2.3.jar:/home/sean/.m2/repository/cglib/cglib-nodep/2.1_3/cglib-nodep-2.1_3.jar:/home/sean/.m2/repository/org/antlr/com.springsource.antlr/2.7.6/com.springsource.antlr-2.7.6.jar:/home/sean/.m2/repository/com/mysql/jdbc/com.springsource.com.mysql.jdbc/5.1.6/com.springsource.com.mysql.jdbc-5.1.6.jar:/home/sean/.m2/repository/edu/emory/mathcs/backport/com.springsource.edu.emory.mathcs.backport/3.1.0/com.springsource.edu.emory.mathcs.backport-3.1.0.jar:/home/sean/.m2/repository/edu/oswego/cs/concurrent/com.springsource.edu.oswego.cs.dl.util.concurrent/1.3.4/com.springsource.edu.oswego.cs.dl.util.concurrent-1.3.4.jar:/home/sean/.m2/repository/org/jboss/javassist/com.springsource.javassist/3.3.0.ga/com.springsource.javassist-3.3.0.ga.jar:/home/sean/.m2/repository/net/sourceforge/cglib/com.springsource.net.sf.cglib/2.1.3/com.springsource.net.sf.cglib-2.1.3.jar:/home/sean/.m2/repository/net/sourceforge/ehcache/com.springsource.net.sf.ehcache/1.4.1/com.springsource.net.sf.ehcache-1.4.1.jar:/home/sean/.m2/repository/net/sourceforge/jsr107cache/com.springsource.net.sf.jsr107cache/1.0.0/com.springsource.net.sf.jsr107cache-1.0.0.jar:/home/sean/.m2/repository/org/aopalliance/com.springsource.org.aopalliance/1.0.0/com.springsource.org.aopalliance-1.0.0.jar:/home/sean/.m2/repository/org/apache/commons/com.springsource.org.apache.commons.beanutils/1.8.0/com.springsource.org.apache.commons.beanutils-1.8.0.jar:/home/sean/.m2/repository/org/apache/commons/com.springsource.org.apache.commons.collections/3.2.0/com.springsource.org.apache.commons.collections-3.2.0.jar:/home/sean/.m2/repository/org/apache/commons/com.springsource.org.apache.commons.dbcp/1.2.2.osgi/com.springsource.org.apache.commons.dbcp-1.2.2.osgi.jar:/home/sean/.m2/repository/org/apache/commons/com.springsource.org.apache.commons.digester/1.8.1/com.springsource.org.apache.commons.digester-1.8.1.jar:/home/sean/.m2/repository/org/apache/commons/com.springsource.org.apache.commons.fileupload/1.2.0/com.springsource.org.apache.commons.fileupload-1.2.0.jar:/home/sean/.m2/repository/org/apache/commons/com.springsource.org.apache.commons.io/1.4.0/com.springsource.org.apache.commons.io-1.4.0.jar:/home/sean/.m2/repository/org/apache/commons/com.springsource.org.apache.commons.logging/1.1.1/com.springsource.org.apache.commons.logging-1.1.1.jar:/home/sean/.m2/repository/org/apache/commons/com.springsource.org.apache.commons.pool/1.3.0/com.springsource.org.apache.commons.pool-1.3.0.jar:/home/sean/.m2/repository/org/apache/el/com.springsource.org.apache.el/6.0.20/com.springsource.org.apache.el-6.0.20.jar:/home/sean/.m2/repository/org/apache/log4j/com.springsource.org.apache.log4j/1.2.15/com.springsource.org.apache.log4j-1.2.15.jar:/home/sean/.m2/repository/org/apache/taglibs/com.springsource.org.apache.taglibs.standard/1.1.2/com.springsource.org.apache.taglibs.standard-1.1.2.jar:/home/sean/.m2/repository/org/apache/tiles/com.springsource.org.apache.tiles/2.1.3/com.springsource.org.apache.tiles-2.1.3.jar:/home/sean/.m2/repository/org/apache/tiles/com.springsource.org.apache.tiles.core/2.1.3/com.springsource.org.apache.tiles.core-2.1.3.jar:/home/sean/.m2/repository/org/apache/tiles/com.springsource.org.apache.tiles.jsp/2.1.3/com.springsource.org.apache.tiles.jsp-2.1.3.jar:/home/sean/.m2/repository/org/apache/tiles/com.springsource.org.apache.tiles.servlet/2.1.3/com.springsource.org.apache.tiles.servlet-2.1.3.jar:/home/sean/.m2/repository/org/dom4j/com.springsource.org.dom4j/1.6.1/com.springsource.org.dom4j-1.6.1.jar:/home/sean/.m2/repository/org/hibernate/com.springsource.org.hibernate/3.2.6.ga/com.springsource.org.hibernate-3.2.6.ga.jar:/home/sean/.m2/repository/org/hibernate/com.springsource.org.hibernate.annotations/3.3.1.ga/com.springsource.org.hibernate.annotations-3.3.1.ga.jar:/home/sean/.m2/repository/org/hibernate/com.springsource.org.hibernate.annotations.common/3.3.0.ga/com.springsource.org.hibernate.annotations.common-3.3.0.ga.jar:/home/sean/.m2/repository/org/hibernate/com.springsource.org.hibernate.ejb/3.3.2.GA/com.springsource.org.hibernate.ejb-3.3.2.GA.jar:/home/sean/.m2/repository/org/hibernate/com.springsource.org.hibernate.validator/4.0.0.GA/com.springsource.org.hibernate.validator-4.0.0.GA.jar:/home/sean/.m2/repository/org/jboss/util/com.springsource.org.jboss.util/2.0.4.GA/com.springsource.org.jboss.util-2.0.4.GA.jar:/home/sean/.m2/repository/org/joda/com.springsource.org.joda.time/1.6.0/com.springsource.org.joda.time-1.6.0.jar:/home/sean/.m2/repository/org/junit/com.springsource.org.junit/4.7.0/com.springsource.org.junit-4.7.0.jar:/home/sean/.m2/repository/org/objectweb/asm/com.springsource.org.objectweb.asm/1.5.3/com.springsource.org.objectweb.asm-1.5.3.jar:/home/sean/.m2/repository/org/objectweb/asm/com.springsource.org.objectweb.asm.attrs/1.5.3/com.springsource.org.objectweb.asm.attrs-1.5.3.jar:/home/sean/.m2/repository/org/tuckey/com.springsource.org.tuckey.web.filters.urlrewrite/3.1.0/com.springsource.org.tuckey.web.filters.urlrewrite-3.1.0.jar:/home/sean/.m2/repository/org/slf4j/com.springsource.slf4j.api/1.5.6/com.springsource.slf4j.api-1.5.6.jar:/home/sean/.m2/repository/org/slf4j/com.springsource.slf4j.log4j/1.5.6/com.springsource.slf4j.log4j-1.5.6.jar:/home/sean/.m2/repository/com/wave2/common/common/4.1/common-4.1.jar:/home/sean/.m2/repository/commons-codec/commons-codec/1.2/commons-codec-1.2.jar:/home/sean/.m2/repository/commons-collections/commons-collections/3.2.1/commons-collections-3.2.1.jar:/home/sean/.m2/repository/commons-httpclient/commons-httpclient/3.1/commons-httpclient-3.1.jar:/home/sean/.m2/repository/commons-lang/commons-lang/2.5/commons-lang-2.5.jar:/home/sean/.m2/repository/commons-logging/commons-logging/1.1.1/commons-logging-1.1.1.jar:/home/sean/.m2/repository/org/apache/cxf/cxf-api/2.2/cxf-api-2.2.jar:/home/sean/.m2/repository/org/apache/cxf/cxf-common-schemas/2.2/cxf-common-schemas-2.2.jar:/home/sean/.m2/repository/org/apache/cxf/cxf-common-utilities/2.2/cxf-common-utilities-2.2.jar:/home/sean/.m2/repository/org/apache/cxf/cxf-rt-bindings-soap/2.2/cxf-rt-bindings-soap-2.2.jar:/home/sean/.m2/repository/org/apache/cxf/cxf-rt-bindings-xml/2.2/cxf-rt-bindings-xml-2.2.jar:/home/sean/.m2/repository/org/apache/cxf/cxf-rt-core/2.2/cxf-rt-core-2.2.jar:/home/sean/.m2/repository/org/apache/cxf/cxf-rt-databinding-jaxb/2.2/cxf-rt-databinding-jaxb-2.2.jar:/home/sean/.m2/repository/org/apache/cxf/cxf-rt-frontend-jaxws/2.2/cxf-rt-frontend-jaxws-2.2.jar:/home/sean/.m2/repository/org/apache/cxf/cxf-rt-frontend-simple/2.2/cxf-rt-frontend-simple-2.2.jar:/home/sean/.m2/repository/org/apache/cxf/cxf-rt-transports-http/2.2/cxf-rt-transports-http-2.2.jar:/home/sean/.m2/repository/org/apache/cxf/cxf-rt-ws-addr/2.2/cxf-rt-ws-addr-2.2.jar:/home/sean/.m2/repository/org/apache/cxf/cxf-tools-common/2.2/cxf-tools-common-2.2.jar:/home/sean/.m2/repository/dom4j/dom4j/1.6.1/dom4j-1.6.1.jar:/home/sean/.m2/repository/org/hibernate/ejb3-persistence/1.0.2.GA/ejb3-persistence-1.0.2.GA.jar:/home/sean/.m2/repository/com/google/code/facebookapi/facebook-java-api/3.0.2/facebook-java-api-3.0.2.jar:/home/sean/.m2/repository/com/google/code/facebookapi/facebook-java-api-annotation-processor/3.0.2/facebook-java-api-annotation-processor-3.0.2.jar:/home/sean/.m2/repository/com/google/code/facebookapi/facebook-java-api-schema/3.0.2/facebook-java-api-schema-3.0.2.jar:/home/sean/.m2/repository/com/sun/xml/fastinfoset/FastInfoset/1.2.2/FastInfoset-1.2.2.jar:/home/sean/.m2/repository/org/apache/geronimo/specs/geronimo-activation_1.1_spec/1.0.2/geronimo-activation_1.1_spec-1.0.2.jar:/home/sean/.m2/repository/org/apache/geronimo/specs/geronimo-annotation_1.0_spec/1.1.1/geronimo-annotation_1.0_spec-1.1.1.jar:/home/sean/.m2/repository/org/apache/geronimo/specs/geronimo-javamail_1.4_spec/1.5/geronimo-javamail_1.4_spec-1.5.jar:/home/sean/.m2/repository/org/apache/geronimo/specs/geronimo-jaxws_2.1_spec/1.0/geronimo-jaxws_2.1_spec-1.0.jar:/home/sean/.m2/repository/org/apache/geronimo/specs/geronimo-stax-api_1.0_spec/1.0.1/geronimo-stax-api_1.0_spec-1.0.1.jar:/home/sean/.m2/repository/org/apache/geronimo/specs/geronimo-ws-metadata_2.0_spec/1.1.2/geronimo-ws-metadata_2.0_spec-1.1.2.jar:/home/sean/.m2/repository/org/hamcrest/hamcrest-core/1.1/hamcrest-core-1.1.jar:/home/sean/.m2/repository/org/hamcrest/hamcrest-library/1.1/hamcrest-library-1.1.jar:/home/sean/.m2/repository/org/hibernate/hibernate-commons-annotations/3.1.0.GA/hibernate-commons-annotations-3.1.0.GA.jar:/home/sean/.m2/repository/org/hibernate/hibernate-core/3.3.1.GA/hibernate-core-3.3.1.GA.jar:/home/s
at org.eclipse.core.runtime.Assert.isTrue(Assert.java:110)
at org.eclipse.core.internal.resources.MarkerInfo.checkValidAttribute(MarkerInfo.java:63)
at org.eclipse.core.internal.resources.MarkerInfo.setAttribute(MarkerInfo.java:146)
at org.eclipse.core.internal.resources.Marker.setAttribute(Marker.java:241)
at org.eclipse.ajdt.internal.ui.ajde.UIMessageHandler.setMessage(UIMessageHandler.java:567)
at org.eclipse.ajdt.internal.ui.ajde.UIMessageHandler.access$7(UIMessageHandler.java:556)
at org.eclipse.ajdt.internal.ui.ajde.UIMessageHandler$1.run(UIMessageHandler.java:318)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1800)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1782)
at org.eclipse.ajdt.internal.ui.ajde.UIMessageHandler.showMessages(UIMessageHandler.java:339)
at org.eclipse.ajdt.internal.ui.ajde.UIMessageHandler.showOutstandingProblems(UIMessageHandler.java:207)
at org.eclipse.ajdt.internal.builder.UIBuildListener.postAJBuild(UIBuildListener.java:197)
at org.eclipse.ajdt.core.builder.AJBuilder.postCallListeners(AJBuilder.java:1352)
at org.eclipse.ajdt.core.builder.AJBuilder.build(AJBuilder.java:258)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:627)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:170)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:201)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:253)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:256)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:309)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:341)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:140)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:238)
EDIT: I couldn't find a related bug for this, so I've logged one here.
[Updated on: Mon, 28 June 2010 06:40] Report message to a moderator
FUDForum. Page generated in 0.02553 seconds
