Home » Eclipse Projects » Buckminster » Headless preferences importing
Headless preferences importing [message #543462] Tue, 29 June 2010 09:44 Go to next message
Geejay is currently offline Geejay
I have a buckminster properties file:
# Where all the output should go
buckminster.output.root=${user.home}/bm
<snip/>
How do I import this into the current headless buckminster workspace? (i.e
lsprefs doesn't show a buckminster.output.root preference)
I am also getting this exception, on my CentOS build box:
INFO: = Could not load library providing platform-specific optimizations
for certain file system operations. This library is not present on all
platforms, so this may not be an error. The resources plug-in will safely
fall back to using java.io.File functionality.
java.lang.Exception: = Could not load library providing platform-specific
optimizations for certain file system operations. This library is not
present on all platforms, so this may not be an error. The resources
plug-in will safely fall back to using java.io.File functionality.
Do I need to install the delta pack into the headless buckminster somehow?
Re: Headless preferences importing [message #543549 is a reply to message #543462] Tue, 29 June 2010 14:07 Go to previous message
Henrik Lindberg is currently offline Henrik Lindberg
You pass a reference to the property file on the command line.
- henrik
> <snip/>
> (i.e lsprefs doesn't show a buckminster.output.root preference)
> platform-specific optimizations for certain file system operations. This
> library is not present on all platforms, so this may not be an error.
> The resources plug-in will safely fall back to using java.io.File
> functionality.
Previous Topic:qualifier replacement in products
Next Topic:Location of predefined actions
Current Time: Sun May 19 03:35:39 EDT 2013
Powered by FUDForum. Page generated in 0.06413 seconds
