| Running Ruby Test::Unit scripts [message #543261] |
Mon, 28 June 2010 16:39  |
Ian Dickinson Messages: 7 Registered: July 2009 |
Junior Member |
I'm trying to run a simple Ruby Test::Unit script under DLTK. When I run the script using 'Run as ...' > 'Ruby test' I get:
| Quote: | /home/ian/dev/java/eclipse-galileo-64-sr-1/configuration/org .eclipse.osgi/bundles/1079/1/.cp/testing/dltk-testunit-runne r.rb:252:in `block in <top (required)>': uninitialized constant Test::Unit::UI::SILENT (NameError)
I'm running on Ubuntu 10.04 64 bit, with Eclipse Build id: 20100218-1602, DLTK 2.0 and ruby 1.9.1. I just did the upgrade to DLTK 2.0, running tests wasn't working before the upgrade either so it's not an issue with the 2.0 update. Any suggestions?
Ian
FUDForum. Page generated in 0.01559 seconds
