Home » Eclipse Projects » Web Tools Project (WTP) » Problem with Eclipse BPEL plugin and org.eclipse.jface
Problem with Eclipse BPEL plugin and org.eclipse.jface [message #511507] Mon, 01 February 2010 14:37 Go to next message
No real name is currently offline No real name
Hello
Im working with Eclipse and Apache ODE (HelloWorld example). Im trying to set up de deploy params to the binding port in my ODE deploy descriptor with the Eclipse plug in and I got this error:
Problems occurred when invoking code from plug-in: "org.eclipse.jface".
stacktrace:
java.lang.LinkageError: javax/wsdl/Binding
at org.eclipse.bpel.apache.ode.deploy.ui.pages.ProcessPage$Port TypeLabelProvider.getColumnText(ProcessPage.java:648)
at org.eclipse.jface.viewers.TableColumnViewerLabelProvider.upd ate(TableColumnViewerLabelProvider.java:70)
at org.eclipse.jface.viewers.ViewerColumn.refresh(ViewerColumn. java:145)
at org.eclipse.jface.viewers.AbstractTableViewer.doUpdateItem(A bstractTableViewer.java:399)
at org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRun nable.run(StructuredViewer.java:481)
at org.eclipse.core.runtime.Platform.run(Platform.java:888)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
at org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct uredViewer.java:2111)
at org.eclipse.jface.viewers.AbstractTableViewer.internalRefres hAll(AbstractTableViewer.java:711)
at org.eclipse.jface.viewers.AbstractTableViewer.internalRefres h(AbstractTableViewer.java:649)
at org.eclipse.jface.viewers.AbstractTableViewer.internalRefres h(AbstractTableViewer.java:636)
at org.eclipse.jface.viewers.StructuredViewer$7.run(StructuredV iewer.java:1457)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1392)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1353)
at org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:1455)
at org.eclipse.jface.viewers.ColumnViewer.refresh(ColumnViewer. java:537)
at org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:1414)
at org.eclipse.bpel.apache.ode.deploy.ui.pages.ProcessPage$Inte rfaceWidgetCellModifier.modify(ProcessPage.java:444)
at org.eclipse.jface.viewers.ColumnViewer$2.setValue(ColumnView er.java:274)
at org.eclipse.jface.viewers.EditingSupport.saveCellEditorValue (EditingSupport.java:113)
at org.eclipse.jface.viewers.ColumnViewerEditor.saveEditorValue (ColumnViewerEditor.java:455)
at org.eclipse.jface.viewers.ColumnViewerEditor.applyEditorValu e(ColumnViewerEditor.java:311)
at org.eclipse.jface.viewers.ColumnViewerEditor$2.applyEditorVa lue(ColumnViewerEditor.java:153)
at org.eclipse.jface.viewers.CellEditor$1.run(CellEditor.java:3 33)
at org.eclipse.jface.viewers.CellEditor.fireApplyEditorValue(Ce llEditor.java:331)
at org.eclipse.jface.viewers.ComboBoxCellEditor.applyEditorValu eAndDeactivate(ComboBoxCellEditor.java:273)
at org.eclipse.jface.viewers.ComboBoxCellEditor.focusLost(Combo BoxCellEditor.java:284)
at org.eclipse.jface.viewers.ComboBoxCellEditor$4.focusLost(Com boBoxCellEditor.java:170)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:137)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1012)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:7 70)
at org.eclipse.swt.custom.CCombo.handleFocus(CCombo.java:844)
at org.eclipse.swt.custom.CCombo$3.handleEvent(CCombo.java:141)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:119 1)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1002)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1008)
at org.eclipse.swt.widgets.Control.sendFocusEvent(Control.java: 2583)
at org.eclipse.swt.widgets.Widget.wmSetFocus(Widget.java:2282)
at org.eclipse.swt.widgets.Control.WM_SETFOCUS(Control.java:457 3)
at org.eclipse.swt.widgets.Table.WM_SETFOCUS(Table.java:5898)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4014 )
at org.eclipse.swt.widgets.Table.windowProc(Table.java:5521)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4589 )
at org.eclipse.swt.internal.win32.OS.SetFocus(Native Method)
at org.eclipse.swt.widgets.Table.sendMouseDownEvent(Table.java: 3574)
at org.eclipse.swt.widgets.Table.WM_LBUTTONDOWN(Table.java:5745 )
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3981 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4602 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:24 10)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3471)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
Im thinking that's a version problem but I dont know which plugin (or jars) replace in order to fix it
Help will be awesome =D
Re: Problem with Eclipse BPEL plugin and org.eclipse.jface [message #539954 is a reply to message #511507] Mon, 14 June 2010 07:57 Go to previous messageGo to next message
angelrego  is currently offline angelrego
Same problem. Has anybody solved that? As in the first post I also think that this is a version problem, but I don't understand why it is not working with the latests versions!!!
Eclipse IDE for SOA DevelopersBuild id: 20100218-1602
java.version=1.6.0_18
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Re: Problem with Eclipse BPEL plugin and org.eclipse.jface [message #541005 is a reply to message #511507] Thu, 17 June 2010 21:41 Go to previous messageGo to next message
Xutao is currently offline Xutao
Same problem.
ODE
GEF
EMF
DTP
WTP
all the most recent version.!
Hope it can be noticed and solved soon!
Re: Problem with Eclipse BPEL plugin and org.eclipse.jface [message #541322 is a reply to message #511507] Sat, 19 June 2010 21:30 Go to previous messageGo to next message
Problem solved by switch back to Eclipse 3.4.
Newer is not always better!Smile
Re: Problem with Eclipse BPEL plugin and org.eclipse.jface [message #541581 is a reply to message #511507] Mon, 21 June 2010 11:30 Go to previous messageGo to next message
Nitin Dahyabhai is currently online Nitin Dahyabhai
On 2/1/2010 2:37 PM, gustavo.romerorz@gmail.com wrote:
> Hello
> stacktrace:
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> iewer.java:1457)
> dViewer.java:1455)
> dViewer.java:1414)
> er.java:274)
> llEditor.java:331)
> ner.java:137)
> (Realm.java:332)
> bench.java:493)
> tarter.java:368)
> tarter.java:179)
You might find more answers in the STP forum:
http://www.eclipse.org/forums/eclipse.stp . Off hand it looks like it
is not compatible with the javax.wsdl bundle that has been loaded into
the VM.
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
Nitin Dahyabhai
Eclipse WTP, IBM
Re: Problem with Eclipse BPEL plugin and org.eclipse.jface [message #543092 is a reply to message #541581] Mon, 28 June 2010 07:44 Go to previous message
solved:
*install eclipse SOA GALILEO
*add bpel plug-in at http://swordfish-tooling.googlecode.com/svn/trunk/org.eclips e.swordfish.third-parties/bpel/ (help/install new software/add url/select bpel)
As reminder http://people.apache.org/~vanto/HelloWorld-BPELDesignerAndOD E.pdf is a good tutorial of how to create a bpel sample
The fix was found at http://wiki.eclipse.org/Swordfish_Documentation:_Installing_ BPEL_Designer_in_Galileo
Previous Topic:Rhino launching connector missing in Java EE EPP
Next Topic:Java EE referenced classpaths broken in Helios?
Current Time: Fri May 24 16:19:33 EDT 2013
Powered by FUDForum. Page generated in 0.03093 seconds
