Home » Modeling » UML2 » UML Factory(set subsetting or Redefined Properties)
UML Factory [message #542808] Sat, 26 June 2010 05:19 Go to next message
zara75  is currently offline zara75
Hi All,
I started using UMLFactory provided by Package org.eclipse.uml2.uml in order to create a UML class diagram.
I succeed to create a classes and associations:
For example
Class c1 = UMLFactory.eINSTANCE.createClass();
Class c2 = UMLFactory.eINSTANCE.createClass();
Property prop1 = UMLFactory.eINSTANCE.createProperty();
Property prop2 = UMLFactory.eINSTANCE.createProperty();
prop1.setType(c1);
prop2.setType(c2);
prop1.setAssociation(ass1);
prop2.setAssociation(ass1);
However, when I tried to set a property prop1 to subset the property porp3, I did not find such a method: setSubsettedProperty(Property) or setRedeffinedProperty(Property)
However, I found that there are the methods
getSubsettedProperties
The same question for Generalization sets
I succeed to create generalizations and generalization set, but How can I add these generalizations to the specific generalization set
I think that this is a strange that the API dont provide such methods, Maybe I miss something here
Thanks in advanced
[Updated on: Sat, 26 June 2010 05:42]
Report message to a moderator
Re: UML Factory [message #542876 is a reply to message #542808] Sat, 26 June 2010 18:55 Go to previous messageGo to next message
Rafael Chaves is currently offline Rafael Chaves
I believe those collections are not derived, so you can do:
prop1.getSubsettedProperties().add(prop2);
Re: UML Factory [message #542877 is a reply to message #542876] Sat, 26 June 2010 18:56 Go to previous message
Thanks, I used that and and its working,
Re: UML Factory [message #628529 is a reply to message #542808] Sat, 26 June 2010 18:55 Go to previous message
Previous Topic:Redefinition Contexts
Next Topic:Re: UML Factory
Current Time: Tue May 21 18:02:57 EDT 2013
Powered by FUDForum. Page generated in 0.01715 seconds
