| [Xpand] Setting up outlet path through Java [message #542751] |
Fri, 25 June 2010 16:31  |
Herat Acharya Messages: 7 Registered: May 2010 |
Junior Member |
How can we set up the outlet path programmatically through Xpand API. current i have the default path in the work flow (oaw) but now i want to enter the path and its the path i have entered will be where my sources should get generated.please tell me how can i achieve that
current i have 2 classes one is as JavaBeans meta model and other is workflow component class extending WorkflowComponentWithModelSlot
this is how i run my workflow..
new WorkflowRunner().run(wfFile ,
monitor, properties, slotContents);
my workflow file is
<workflow>
<property file="example.properties"/>
<!-- Is used to instance the model. The model is put in the modelSlot 'model'-->
<component class=" com.tibco.mdm.repositorymodel.wsdlgen.codegen.MetaModelWorkF low ">
<modelSlot value="model"/>
</component>
<!-- Run the Generator -->
<component id="generator" class="org.openarchitectureware.xpand2.Generator" skipOnErrors="true">
<!-- The Meta Model is JavaBeans based -->
<metaModel class="org.openarchitectureware.type.impl.java.JavaMetaModel ">
<typeStrategy class=" org.openarchitectureware.type.impl.java.beans.JavaBeansStrat egy "/>
</metaModel>
<fileEncoding value="ISO-8859-1"/>
<!-- Call Define Root in Template Root for our model put in the modleslot 'model' -->
<expand value=" com::tibco::mdm::repositorymodel::wsdlgen::xpt::skeleton::ma in FOR model"/>
<outlet path="${srcGenPath}">
</outlet>
<beautifier
class="org.openarchitectureware.xpand2.output.JavaBeautifier " />
</component>
</workflow>
what changes would i have to make here so that it can accept the path that is entered through a Java prog.
FUDForum. Page generated in 0.03176 seconds
