| Open Declaration/Selection (F3) Doesn't Work on JSPs [message #542101] |
Wed, 23 June 2010 16:55  |
Jeremy Messages: 5 Registered: July 2009 |
Junior Member |
So I love Eclipse, and love the Web Tools Project ... but I have a little problem. Whenever I try and use the Open Selection (aka Open Declaration) tool (more commonly known as CTRL+click or F3) on a JSP variable, Eclipse opens up the generated .java file for that JSP (instead of just taking me to the part of the JSP that declares the variable). Now if I F3 a class in a JSP, Eclipse does take me to that class, and similarly if I F3 a tag it takes me to either the .tag file or the related .tld file, as appropriate. So the only problem is just with variables declared in a JSP.
Has anyone ever seen this before, and if so do you have any ideas on how I could fix it?
| Re: Open Declaration/Selection (F3) Doesn't Work on JSPs [message #542260 is a reply to message #542101] |
Thu, 24 June 2010 07:27   |
Nitin Dahyabhai Messages: 1843 Registered: July 2009 |
> I could fix it?
I've seen it before, but not in Helios. Which release are you using?
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
Nitin Dahyabhai
Eclipse WTP, IBM
FUDForum. Page generated in 0.01678 seconds
