Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Missing imported package (Eclipse 3.6RC4 Milestone)
Missing imported package [message #541405] Sun, 20 June 2010 21:40 Go to next message
celeraman + is currently offline celeraman +
When export a RCP product I get the following error:
osgi> diag 161
reference:file:plugins/org.eclipse.swt_3.6.0.v3650b.jar [161]
  Direct constraints which are unresolved:
    Missing dynamically imported package org.eclipse.swt.accessibility2_0.0.0.
    Missing dynamically imported package org.mozilla.xpcom_0.0.0.
I'm running under Eclipse 3.6RC4 target platform and JavaSE-1.6.
There aren't error running the application inside the IDE. And no errors validating the product before export it too.
Any help are welcome! Thanks!
Re: Missing imported package [message #541800 is a reply to message #541405] Tue, 22 June 2010 10:44 Go to previous messageGo to next message
Grant Gayed is currently offline Grant Gayed
These are both dynamic plug-in imports, meaning that they are not required
to be there (but if they are then swt's functionality is extended
accordingly). The absence of these plug-ins should not cause the loading of
swt to fail in any context. Is this actually failing for you, or is it
working and you're just looking at osgi's logged info? If it's causing your
swt load to fail then it seems like a problem either in osgi or in the
export of your rcp app, because the attempted importing of these two
plug-ins should never cause a failure.
Grant
"celeraman" <dany.eudes@gmail.com> wrote in message
news:hvmfui$h14$1@build.eclipse.org...
> osgi> diag 161
Re: Missing imported package [message #541891 is a reply to message #541800] Tue, 22 June 2010 21:25 Go to previous message
@Grant,
thank you for your reply.
I dropped out these following plugins from my EclipseLink feature and Equinox P2 feature and the error was gone:
org.eclipse.persistence.dbws_2.1.0.v20100614-r7608
org.eclipse.equinox.p2.ui.sdk_1.0.100.v20100513
I cannot figure out why. Shocked
I will continue to investigate that.
Previous Topic:Galileo Internal Web Browser
Next Topic:Backgorund mdoe inherit doesn't work with windoes theme classic
Current Time: Tue May 21 16:18:03 EDT 2013
Powered by FUDForum. Page generated in 0.01771 seconds
