| Excluded files from build path get exported to jar [message #540937] |
Thu, 17 June 2010 12:51  |
Ely Schoenfeld Messages: 4 Registered: June 2010 |
Junior Member |
Hello all.
I've been searching the web (eclipse bugs and forums) but haven't been able to find a solution.
In my souce tree I have some files that I use to generate some java classes during development. I don't want these files to get into the jar file.
Normally, those files get copied into to the "bin" directory tree everytime the project gets built.
I found a way to prevent this by adding some exclusion patterns:
| Quote: | ...go to the project->Properties->Java Build Path. Select Source tab, expand the source folder, you will see (Exclusion filters), click on it and then the "Edit" button.
Now, imagine I have a folder with some source files
src/com/mitalteli/cfd/extracted/
somethinig.bat
class1.java
class2.java
If I don't put any exclusions, and run the "Export to runnable jar file wizard", the generated jar contets are:
com
|->mitalteli
|->cfd
|->extracted
something.bat
class1.class
class2.class
META-INF
|->MANIFEST.MF
Ofcourse I don't want the "something.bat" there.
So I added the following exclusions:
**/*.bat
**/*.swp
**/*.xjb
Now, when I export it again, the jar contets are:
com
|->mitalteli
|->cfd
|->extracted
class1.class
class2.class
META-INF
|->MANIFEST.MF
src
|->com
|->mitalteli
|->cfd
|->extracted
something.bat
It's very wierd. As you can see, the "excluded" file is taken off the main file structure, but is then placed in a "src" direcotry.
Is this a bug? I mean. If some files are excluded from the build path, they shouldn't be added to the jar file. Am I right?
Does anybody has any pointers in order to fix this?
Any help would be very appreciated.
Ely.
[Updated on: Thu, 17 June 2010 12:54] Report message to a moderator
| Re: Excluded files from build path get exported to jar [message #541174 is a reply to message #540937] |
Fri, 18 June 2010 10:30   |
Dani Megert Messages: 3801 Registered: July 2009 |
Ely wrote:
> Hello all.
> jar file.
> Quote:
> somethinig.bat
> class1.java
> class2.java
> com
> |->mitalteli
> |->cfd
> |->extracted
> something.bat
> class1.class
> class2.class
> META-INF
> |->MANIFEST.MF
> So I added this:
> **/*.bat
> **/*.swp
> **/*.xjb
> Now, when I add the exclusions and export it again, the jar contets are:
> com
> |->mitalteli
> |->cfd
> |->extracted
> class1.class
> class2.class
> META-INF
> |->MANIFEST.MF
> src
> |->com
> |->mitalteli
> |->cfd
> |->extracted
> something.bat
No, you are wrong. Build path means it's used to to execute but
'something.bat' might be a simple file that's read by your code. The
exporter cannot have any clue about this. If you want to control this
then you'd better use the 'JAR file' exporter where you can select the
individual resources.
Dani
> Ely.
| Re: Excluded files from build path get exported to jar [message #541509 is a reply to message #541129] |
Mon, 21 June 2010 08:30   |
Junior Member |
| Quote: | My guess is that's deliberate, if you are generating source. What if
you don't generate source into your jar?
PW
Paul Webster
Thank you for answering Paul.
Well... There is no "src" directory unles I add the exclusion rules. I was searching for an option to disable source inclusion in the jar, but couldn't find it.
Do you happen to know where is it if it exists?
Thanks in advance.
Ely.
EDIT: I've just found the eclipse 3.1 has a checkbox for including the source in the jar. Bit I'm Using the Eclipse IDE for Java EE Developers version 1.2.1 and that's why it doesn't have one. (I guess)
[Updated on: Mon, 21 June 2010 09:28] Report message to a moderator
| Re: Excluded files from build path get exported to jar [message #541514 is a reply to message #541174] |
Mon, 21 June 2010 08:41  |
Junior Member |
Hello Dani.
Thank you for taking the time to answering my questions.
| Quote: | > Is this a bug? I mean. If some files are excluded from the build path,
Dani
Hmmm....
I'm not sure I agree. I don't understand why you say the "build" path has any thing to do with the application execution.
As far as I can tell, the "build path" is used to find all the resources needed to complile-link-pack a project wen converting it to executable. Isn't it right? Not the execution itself.
For instance, if you see the eclipse's help, you will find:
Java Build Path
The options in this page indicate the build path settings for a Java project.
The build class path is a list of paths visible to the compiler when building the project.
That's exactly why I was thinking that if I make an exclusion there, those files shouldn't be added to the final jar, as they shouldn't be used when building it.
If there is no other way, I'll find a way to build my jar manually. But I hope there is a better way.
Any other ideas?
Ely.
EDIT: No, I wasn't entirely right. You are right when you say that those files could be used by the application while running, and that's why the jar creation couldn't know if it had to include them or not.
But I still don't know why it creates a src directory when those files are excluded from the building process.
[Updated on: Mon, 21 June 2010 09:00] Report message to a moderator
FUDForum. Page generated in 0.02449 seconds
