Home » Modeling » Epsilon » [Patch] Clash between "default" variables and "default" (new?) keyword in Epsilo
[Patch] Clash between "default" variables and "default" (new?) keyword in Epsilo [message #541391] Sun, 20 June 2010 15:56 Go to next message
Eclipse User
Originally posted by: antonio.garciadominguez.uca.es
--nextPart4661172.zPGA5PUh9M
Content-Type: text/plain; charset="ISO-8859-1"
Content-Transfer-Encoding: 7Bit
Hi all,
I just updated to the latest version of Epsilon in SVN (r1064) and I ran
into some problems when running my EuGENia fix scripts for the Ecore code
generation models. Apparently, there was a parse error in this file:
plugins/org.eclipse.epsilon.eugenia/transformations/ECoreUti l.eol
It said that there was a problem line 1, but when I opened this file with
the Epsilon editor, the parsing errors were around line 211. It looks like
"default" has now become a keyword, and there is a variable named "default"
in the labelHasIcon operation for the ECore!EClass type. Renaming it to
something else (such as defaultValue) solved the problem. Now everything
works great, as usual ;-).
I've attached a patch which seems to fix it for the previous file and this
one, which also uses "default" as a variable:
plugins/org.eclipse.epsilon.eugenia/transformations/Ecore2Ge nModel.etl
However, there seems to be an access to a field called "default" in this
other file. Would that parse correctly?
examples/org.eclipse.epsilon.examples.oo2db/OO2DB.etl
Well, that's all my quick "grep"ping turned up. Hope it helps :-).
Keep up the good work,
Antonio
Content-Type: text/x-patch; name="fix-for-default.patch"
Content-Disposition: attachment; filename="fix-for-default.patch"
Content-Transfer-Encoding: 8Bit
diff --git a/plugins/org.eclipse.epsilon.eugenia/transformations/ECoreU til.eol b/plugins/org.eclipse.epsilon.eugenia/transformations/ECoreU til.eol
index d1f5ac1..5c274a7 100644
--- a/plugins/org.eclipse.epsilon.eugenia/transformations/ECoreU til.eol
+++ b/plugins/org.eclipse.epsilon.eugenia/transformations/ECoreU til.eol
@@ -211,7 +211,7 @@ operation ECore!EClass hasInternalLabel() : Boolean {
@cached
-operation ECore!EClass labelHasIcon(default : Boolean) : Boolean {
+operation ECore!EClass labelHasIcon(defaultValue : Boolean) : Boolean {
var ann : String;
if (self.isNode()) ann := 'gmf.node';
@@ -219,7 +219,7 @@ operation ECore!EClass labelHasIcon(default : Boolean) : Boolean {
var hasIcon := self.getAnnotationValue(ann, 'label.icon');
- if (hasIcon.isUndefined()) return default;
+ if (hasIcon.isUndefined()) return defaultValue;
else if (hasIcon = 'true') return true;
else return false;
diff --git a/plugins/org.eclipse.epsilon.eugenia/transformations/Ecore2 GenModel.etl b/plugins/org.eclipse.epsilon.eugenia/transformations/Ecore2 GenModel.etl
index 81ec21d..5584e49 100644
--- a/plugins/org.eclipse.epsilon.eugenia/transformations/Ecore2 GenModel.etl
+++ b/plugins/org.eclipse.epsilon.eugenia/transformations/Ecore2 GenModel.etl
@@ -196,7 +196,7 @@ operation Ecore!EModelElement hasAnnotation(label : String) : Boolean {
return false;
-operation Ecore!EModelElement getAnnotation(label : String, default : Any) : Any {
+operation Ecore!EModelElement getAnnotation(label : String, defaultValue : Any) : Any {
// GenModel -> "http://www.eclipse.org/emf/2002/GenModel"
@@ -212,13 +212,13 @@ operation Ecore!EModelElement getAnnotation(label : String, default : Any) : Any
return det.value;
else {
- return default;
+ return defaultValue;
-operation Ecore!EModelElement getEnumerationAnnotation(label : String, eObject : Any, default : Any) {
+operation Ecore!EModelElement getEnumerationAnnotation(label : String, eObject : Any, defaultValue : Any) {
- var result = self.getAnnotation(label, default);
+ var result = self.getAnnotation(label, defaultValue);
if (result.isTypeOf(String)) {
@@ -236,26 +236,26 @@ operation Ecore!EModelElement getEnumerationAnnotation(label : String, eObject :
eEnum.getELiterals().collect(l|l.name).concat("/") +
" but was " + result + " instead");
- return default;
else {
- return default;
-operation Ecore!EModelElement getBooleanAnnotation(label : String, default : Boolean) : Boolean {
+operation Ecore!EModelElement getBooleanAnnotation(label : String, defaultValue : Boolean) : Boolean {
if (result == "true") return true;
else if (result == "false") return false;
else {
printWarning("Value of " + label + " was expected to be true/false but was " + result + " instead");
- return default;
else {
- return default;
--nextPart4661172.zPGA5PUh9M--
Re: [Patch] Clash between "default" variables and "default" (new?) keyword in Ep [message #541439 is a reply to message #541391] Mon, 21 June 2010 03:57 Go to previous message
Dimitrios Kolovos is currently offline Dimitrios Kolovos
Hi Antonio,
Many thanks for reporting this! We've recently added a switch statement
to EOL so "switch", "case" and "default" are all reserved keywords from
now on. Good thing this didn't make it into a stable release :)
Dimitris
Antonio García Domínguez wrote:
> Hi all,
> Antonio
Re: [Patch] Clash between "default" variables and "default" (new?) keyword in Ep [message #590228 is a reply to message #541391] Mon, 21 June 2010 03:57 Go to previous message
Hi Antonio,
Dimitris
> Hi all,
> Antonio
Previous Topic:[Patch] Clash between "default" variables and "default" (new?) keyword in Epsilo
Next Topic:Accessing MapInfo structure from ECL
Current Time: Sun May 19 19:25:33 EDT 2013
Powered by FUDForum. Page generated in 0.01684 seconds
