Home » Eclipse Projects » Platform - User Assistance (UA) » mathml in Infocenter(mathml not displaying correctly in Infocenter)
mathml in Infocenter [message #538845] Tue, 08 June 2010 14:38 Go to next message
David Rawlins is currently offline David Rawlins
I have created some xhtml help files containing mathml equations from a Word document using MathType. If I open these files using a browser, they display correctly, but if I include them in the eclipse Infocenter, they do not. I'm assuming the problem is that the Infocenter is serving the files as html as opposed to xhtml. Is there a way to tell Infocenter to serve the pages as xhtml?
Dave
Re: mathml in Infocenter [message #540446 is a reply to message #538845] Wed, 16 June 2010 04:17 Go to previous messageGo to next message
daus salar is currently offline daus salar
Hi David,
I have the same problem and wonder whether you found a solution. I looked in the eclipse help for XHTML in help and found
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/ua_help_content_xhtml.htm
But it does not work for me. I also tried to open my generated Infocenter in Firefox, but it also did not work.
I think the index.jsp must indicate that there is xhtml code, but I do not find a way to let it do so.
Daus
Re: mathml in Infocenter [message #540591 is a reply to message #540446] Wed, 16 June 2010 11:30 Go to previous messageGo to next message
Hi Daus,
What version of Eclipse are you using? Note that the help page you are referring to has changed for Galileo:
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse . platform.doc.isv/guide/ua_help_content_xhtml.htm
Are you able to test your User Assistance plugin by clicking the link "Launch an Eclipse application"? If so, make sure Firefox is your default browser and in the launched eclipse go to Preferences > Help and select "Open help contents in an external browser". If that works then I suspect there is a problem with the command you are using to start the Infocenter.
Dave
Re: mathml in Infocenter [message #541222 is a reply to message #540591] Fri, 18 June 2010 14:22 Go to previous message
Chris Goldthorpe is currently offline Chris Goldthorpe
I notice that a bug was filed - https://bugs.eclipse.org/bugs/show_bug.cgi?id=317215. I'll take a look into it.
Re: mathml in Infocenter [message #624185 is a reply to message #540591] Fri, 18 June 2010 14:22 Go to previous message
I notice that a bug was filed - https://bugs.eclipse.org/bugs/show_bug.cgi?id=317215 I'll take a look into it.
Previous Topic:Welcome page blank when started with Help->Welcome
Next Topic:Welcome page blank when started with Help->Welcome
Current Time: Fri May 24 10:46:15 EDT 2013
Powered by FUDForum. Page generated in 0.02784 seconds
