Home » Eclipse Projects » Platform - User Assistance (UA) » Cheat Sheets in Menu
Cheat Sheets in Menu [message #539422] Thu, 10 June 2010 12:40 Go to next message
Jeff  is currently offline Jeff
I've been looking into creating cheat sheets for a couple of days now, and I think I have it down except one part.
Is there a way to have a cheat sheet show up in the host IDE under the "Select a cheat sheet from the list:" section?
One web site I read said it only shows up in that section when you launch the plug-in as an Eclipse application.
Re: Cheat Sheets in Menu [message #539603 is a reply to message #539422] Fri, 11 June 2010 09:25 Go to previous messageGo to next message
OK, this is obviously a set-up issue with Eclipse. At work I followed all of the instructions and the Cheat Sheet does not show up in the main menu of the IDE, but it will if I run the plugin as an Eclipse application. However, I just deployed the plugin on my computer at home and restarted Eclipse and there is the Cheat Sheet...right there in the menu where it's supposed to be. I'd say the Eclipse configuration at work is different than at home.
Re: Cheat Sheets in Menu [message #540043 is a reply to message #539422] Mon, 14 June 2010 12:43 Go to previous messageGo to next message
Hmm...not a set-up issue either. After some more searching I read a forum with a similar question and the proposed solution was to run "eclipse.exe - clean". I tried that out and everything is now working as it should.
Re: Cheat Sheets in Menu [message #540052 is a reply to message #539603] Mon, 14 June 2010 13:12 Go to previous messageGo to next message
No Message Body
[Updated on: Mon, 14 June 2010 13:13]
Report message to a moderator
Re: Cheat Sheets in Menu [message #541214 is a reply to message #539422] Fri, 18 June 2010 13:46 Go to previous message
Chris Goldthorpe is currently offline Chris Goldthorpe
Glad you were able to figure it out.
Re: Cheat Sheets in Menu [message #624174 is a reply to message #539603] Mon, 14 June 2010 13:12 Go to previous message
Previous Topic:Infocenter -- what URL will load the infocenter and run a search immediately?
Next Topic:Cheat Sheets in Menu
Current Time: Mon May 20 09:26:32 EDT 2013
Powered by FUDForum. Page generated in 0.02565 seconds
