| [Acceleo] No common supertype error [message #540304] |
Tue, 15 June 2010 11:09  |
Frank Messages: 3 Registered: April 2010 |
Junior Member |
I've tried to create a Java Service Wrapper (using the wizard), but I'm receiving some compile errors.
My Java Service is called UMLServices.
Here's the method that is causing an issue:
public boolean isMarked(Element element, String mark)
for (Stereotype stereotype : element.getAppliedStereotypes())
if (mark.equalsIgnoreCase(stereotype.getName()))
return true;
for (String keyword : element.getKeywords())
if (keyword.equalsIgnoreCase(mark))
return true;
return false;
The generated Acceleo mtl file looks like this:
[module umlservices('http://www.eclipse.org/uml2/2.1.0/UML')/]
[query public isMarked(arg0 : Element, arg1 : String) : Boolean
= invoke('com.pwc.us.mda.services.UMLServices', 'isMarked(org.eclipse.uml2.uml.Element, java.lang.String)', Sequence{arg0, arg1}) /]
It seems fine, but the compiler is showing an error:
Type mismatch. No common supertype: (Element), (String)
I've done some debugging and it seems to happen when my service method takes more than one parameter that do not have a common superclass. Why? How can I change my service method or query to get this to work?
Frank
| Re: [Acceleo] No common supertype error [message #540809 is a reply to message #540506] |
Thu, 17 June 2010 08:28  |
Laurent Goubet Messages: 1545 Registered: July 2009 |
--------------010705030905030504020809
Content-Type: text/plain; charset=UTF-8; format=flowed
Hi Frank,
Unfortunately, most type checking issues are pure OCL. The best answer I
can give you is : your RSA environment is based on Eclipse 3.4 or 3.5,
thus OCL 1.2 or 1.3. A good number of such issues were fixed with OCL
1.3, even more have been fixed with OCL 3.0 (available in Eclipse 3.6,
Helios).
I believe that what you get here was fixed with OCL 1.3, but I might be
mistaken. Either way, if you cannot upgrade your RSA environment, I
cannot propose any intelligent workaround for this.
Laurent Goubet
Obeo
Frank wrote:
> I found that this same code works in a pure Helios Modeling environment.
> I get the compile error while in an RSA environment, with the same
> Acceleo 3.0.X build installed. Does anyone know what plug-in dependency
> might be causing this?
Content-Type: text/x-vcard; charset=utf-8;
name="laurent_goubet.vcf"
Content-Disposition: attachment;
filename="laurent_goubet.vcf"
YmVnaW46dmNhcmQNCmZuOkxhdXJlbnQgR291YmV0DQpuOkdvdWJldDtMYXVy ZW50DQpvcmc6
PGEgaHJlZj0iaHR0cDovL3d3dy5vYmVvLmZyIj5PYmVvPC9hPg0KZW1haWw7 aW50ZXJuZXQ6
bGF1cmVudC5nb3ViZXRAb2Jlby5mcg0KdXJsOmh0dHA6Ly93d3cub2Jlby5m cg0KdmVyc2lv
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------010705030905030504020809--
FUDForum. Page generated in 0.01676 seconds
