Home » Eclipse Projects » EclipseLink » Recommended way to store XML data with EL
Recommended way to store XML data with EL [message #540468] Wed, 16 June 2010 05:37 Go to next message
marco is currently offline marco
I am looking for a best practice solution for storing XML data in a database with EL. I receive an XML document from a WS (using Apache CXF) which is unmarshaled to an object structure using JAXB. After some processing, I would like to store the data in a MySQL db using JPA/EL. I don't need to query or manipulate the data later on - i.e., the data could be stored as a BLOB. I thought about marshaling the data to a byte[] or to a string (preferable) and store it as a property of an entity.
Is there any better solution supported by EL or should I go with the marshaling approach (if so, are there any major performance differences between marshaling to byte[] or string)?
Thanks in advance for your thoughts.
marco
Re: Recommended way to store XML data with EL [message #540563 is a reply to message #540468] Wed, 16 June 2010 10:21 Go to previous messageGo to next message
Blaise Doughan is currently offline Blaise Doughan
Hello Marco,
For this particular use case (receive XML, store XML as BLOB in database), I would recommend not using JAXB at all. Are you able to change your web service client to recieve the data as XML instead of POJOs?
If you want/need to receive the data as POJOs then assuming you are using the default UTF 8 encoding it is noticably faster to write to a byte[] using ByteArrayOutputStream than to write to a String using StringWriter (atleast it is for EclipseLink JAXB).
-Blaise
Re: Recommended way to store XML data with EL [message #540792 is a reply to message #540468] Thu, 17 June 2010 07:41 Go to previous message
Hello Blaise,
thanks for your advices. If possible (also from a requirements point of view), I will try to avoid using JAXB at the CXF interface. Anyway, I will persist the entire message as a byte[] as you suggested.
regards,
marco
Previous Topic:PluralAttribute.getJavaType returns element type instead of collection type
Next Topic:Readonly ManyToMany mapping?
Current Time: Tue May 21 04:23:21 EDT 2013
Powered by FUDForum. Page generated in 0.01478 seconds
