Home » Modeling » M2T (model-to-text transformation) » In my model, Class not found or is abstract
In my model, Class not found or is abstract [message #540786] Thu, 17 June 2010 07:25 Go to next message
MaximeLecourt  is currently offline MaximeLecourt
I made a metamodel, where Items is my container EClass.
part of the metamodel :
<ecore:EPackage xmi:version="2.0"
    xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
    xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="hla"
    nsURI="http://hla/1.0" nsPrefix="hla">
  <eClassifiers xsi:type="ecore:EClass" name="Items">
    <eStructuralFeatures xsi:type="ecore:EReference" name="entities" upperBound="-1"
        eType="#//HEntity" derived="true" containment="true"/>
  </eClassifiers>
So after that I wanted to define a model
<hla:Items xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:metamodel="http://www.example.org/metamodel" xsi:schemaLocation="http://www.example.org/metamodel metamodel/hla.ecore">
</hla:Items>
But I get "Class 'Items' is not found or is abstract". The most surprising is that it worked for a while.
One day I shall master M2T, but that day has yet to come...
Re: In my model, Class not found or is abstract [message #540819 is a reply to message #540786] Thu, 17 June 2010 08:33 Go to previous messageGo to next message
Laurent Goubet is currently offline Laurent Goubet
--------------000605090900040001000302
Content-Type: text/plain; charset=UTF-8; format=flowed
Hi Maxime,
If I understand correctly, this is more of an EMF question than it is an
M2T question, I added the emf newsgroup to the to: list of this answer.
Laurent Goubet
Obeo
Maxime Lecourt wrote:
> upperBound="-1"
> </eClassifiers>
> </hla:Items>
Content-Type: text/x-vcard; charset=utf-8;
name="laurent_goubet.vcf"
Content-Disposition: attachment;
filename="laurent_goubet.vcf"
YmVnaW46dmNhcmQNCmZuOkxhdXJlbnQgR291YmV0DQpuOkdvdWJldDtMYXVy ZW50DQpvcmc6
PGEgaHJlZj0iaHR0cDovL3d3dy5vYmVvLmZyIj5PYmVvPC9hPg0KZW1haWw7 aW50ZXJuZXQ6
bGF1cmVudC5nb3ViZXRAb2Jlby5mcg0KdXJsOmh0dHA6Ly93d3cub2Jlby5m cg0KdmVyc2lv
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------000605090900040001000302--
Re: In my model, Class not found or is abstract [message #540852 is a reply to message #540819] Thu, 17 June 2010 09:45 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
I see the package's nsURI is "http://hla/1.0" but I don't see an xmlns
declaration for that (so the XML looks invalid) nor any other use of the
package's namespace (so the instance doesn't conform to the model).
Laurent Goubet wrote:
> Hi Maxime,
> an M2T question, I added the emf newsgroup to the to: list of this
> answer.
> Laurent Goubet
> Obeo
>> <?xml version="1.0" encoding="UTF-8"?>
>> upperBound="-1"
>> </eClassifiers>
>> </hla:Items>
Re: In my model, Class not found or is abstract [message #540859 is a reply to message #540786] Thu, 17 June 2010 09:50 Go to previous messageGo to next message
I didn't find any tutorial or documentation regarding how to define a model (didn't know what to search for), do you know where I could find some ?
Until now I've been going by trial and error Embarrassed
Re: In my model, Class not found or is abstract [message #540875 is a reply to message #540859] Thu, 17 June 2010 10:18 Go to previous messageGo to next message
--------------010004070206060007020802
Maxime, please respond on the EMF forum (your thread is there :
http://www.eclipse.org/forums/index.php?t=msg&th=170220 ) as I don't
know if Ed monitors the M2T forum.
> some ?
> Until now I've been going by trial and error :blush:
--------------010004070206060007020802--
Re: In my model, Class not found or is abstract [message #540877 is a reply to message #540786] Thu, 17 June 2010 10:22 Go to previous message
Thanks, just did it.
Previous Topic:[Xpand]duplication problem in html report
Next Topic:[Acceleo] Launching a module from Java
Current Time: Thu May 23 04:22:45 EDT 2013
Powered by FUDForum. Page generated in 0.01871 seconds
