Home » Eclipse Projects » Eclipse Examples » Problem with package structure(Problem with package structure)
Problem with package structure [message #539982] Mon, 14 June 2010 10:03 Go to next message
No real name is currently offline No real name
I imported a project using build.xml. My source files are in a single folder instead of package structure. But package is defined in the source files. When these files are loaded into eclipse, it gives error related to package. But I am to compile the project. But the classes are not generated in the corresponding packages as specified in the source file. If I compile the ant target seperatly outside eclipse , then the classes are generated in package structure. In build.xml , for javac destdir is specified.
Can anyone help me in resolving these package issue in eclipse. The condition is , I should not create proper package structure for source files and I should not remove the package declaration from the source file.
Thanks and Regards,
Kumar Thirumalai
Re: Problem with package structure [message #540650 is a reply to message #539982] Wed, 16 June 2010 16:12 Go to previous message
Wayne Beaton is currently offline Wayne Beaton
I recommend that you pose this question on the eclipse.newcomer forum.
Good luck,
Wayne
thirumalaikumar@rediffmail.com wrote:
> Thanks and Regards,
> Kumar Thirumalai
Previous Topic:Missing WYSIWYG P JSP Palette
Next Topic:Missing WYSIWYG P JSP Palette
Current Time: Sat May 18 19:53:20 EDT 2013
Powered by FUDForum. Page generated in 0.01588 seconds
