Home » Eclipse Projects » Eclipse Platform » actions and keybindings
actions and keybindings [message #540366] Tue, 15 June 2010 16:15 Go to next message
Lidder is currently offline Lidder
Member
I Have two drawers (SWT expandBars) in my custom outline view. I need to provide delete actions in both the drawers and link them to the eclipse delete key binding. The two drawers present different information and so that delete actions have to be separate actions.
Drawer 1: the delete action sits in the actionbar
 ActionRegistry registry = this.editor.getActionRegistry();
    IActionBars bars = pageSite.getActionBars();
    bars.setGlobalActionHandler(ActionFactory.CUT.getId(), registry.getAction(CustomCutAction.ACTION_ID));
    bars.setGlobalActionHandler(ActionFactory.COPY.getId(), registry.getAction(CustomCopyAction.ACTION_ID));
    bars.setGlobalActionHandler(ActionFactory.PASTE.getId(), registry.getAction(CustomPasteAction.ACTION_ID));
    bars.setGlobalActionHandler(ActionFactory.DELETE.getId(), registry.getAction(CustomDeleteAction.ACTION_ID));
Drawer 2
     IPageSite pageSite = this.getSite();
		IHandlerService handlerService = (IHandlerService) pageSite.getService(IHandlerService.class);
		RemoveItemAction deleteAction = new RemoveItemAction(pageSite.getPage(), tree);
		handlerService.activateHandler(ActionFactory.DELETE.getId(), new ActionHandler(deleteAction));
The problem is that the CustomDeleteAction runs in both drawers when I press the delete key. I guess the reason is that I am not allowed to over write the binding? Does anybody have an idea as to how I can resolve this issue.
Thank you very much !!
Re: actions and keybindings [message #540529 is a reply to message #540366] Wed, 16 June 2010 08:32 Go to previous messageGo to next message
Paul Webster is currently offline Paul Webster
You only get one DELETE action and/or handler per part (editor or view).
Look at org.eclipse.ui.actions.TextActionHandler and how it is used.
That allows you to provide a delete action for your view, but have
delete on multiple text controls work as well. You will probably need
to write something similar yourself, so you can provide DELETE once and
have it delegate to the expand bar that has focus/activate
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: actions and keybindings [message #540619 is a reply to message #540366] Wed, 16 June 2010 13:44 Go to previous message
Member
Thank you Paul. I am now checking if the control in drawer has focus when the delete is pressed. Seems to work.
Upkar.
Previous Topic:Eclipse with wide screen
Next Topic:Programmatic handler enablement
Current Time: Sun May 19 18:46:28 EDT 2013
Powered by FUDForum. Page generated in 0.02486 seconds
