| Can't hide *.svn-base files from search results [message #539766] |
Sat, 12 June 2010 14:38  |
Lars Gustafsson Messages: 19 Registered: June 2010 |
Junior Member |
While Java programming I can't hide *.svn-base files from search results. I press ctrl-h and then the tab "file-search" enter my string and hit "Search". I've installed Subclipse and Subversive and tried to set them up properly. But I still get hits on .svn folders (especially *.svn-base). I also selected in Filters to exclude .resources and the custom pattern *.svn*
How do you avoid getting hits on .svn folders when performing a file-search?
I'm using:
Eclipse IDE for Java Developers
Build id: 20100218-1602
FUDForum. Page generated in 0.01821 seconds
