| gray solid, non-movable rectangle on top of all sub-windows (hides code text) [message #531836] |
Thu, 06 May 2010 06:29  |
Missing name Mising name Messages: 10 Registered: April 2010 |
Junior Member |
Recently I updated Eclipse to newest version, after that whenever I run Eclipse, a gray rectangle appears on the top of all sub-windows. This rectangle hides code text and is non-movable. I have a backup copy of Eclipse 3.4.1 and this problem does not exist there. Also I have found this topic, in point 2 user described somehow similar situation:
http://www.eclipse.org/forums/index.php?t=msg&goto=51062 1&
However, I have not checked if the problem lies in that. As for now I reverted back to Eclipse 3.4.1, but I'm reporting this bug as it's quite strange.
This is on Linux Slackware, Fluxbox 1.1.1, Eclipse Build id: 20100218-1602, Java+CDT, no additional plugins; problem does not exist in Eclipse 3.4.1 and is always repeatable.
Please refer to this screenshot:
[Updated on: Thu, 06 May 2010 06:31] Report message to a moderator
| Re: gray solid, non-movable rectangle on top of all sub-windows (hides code text) [message #539913 is a reply to message #531836] |
Mon, 14 June 2010 05:29  |
Dani Megert Messages: 3801 Registered: July 2009 |
> situation:
> quite strange.
> in Eclipse 3.4.1
I suggest you switch 3.6 RC4 and if you still see this problem then
please file a bug report against Platform Text
( https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform).
Dani
> http://img243.imageshack.us/i/eclipsebug.png/
FUDForum. Page generated in 0.01872 seconds
