Home » Modeling » AMW » HTTP Status 404" error when starting tomcat
HTTP Status 404" error when starting tomcat [message #539772] Sat, 12 June 2010 16:40
Swetha  is currently offline Swetha
I get the following error while I run my project on eclipse. My project was working before and suddenly started getting this error. I seriously don't know what changes I made . Please help me out with this error.
Thank in advance.
Jun 12, 2010 1:25:08 PM org.apache.tomcat.util.digester.SetPropertiesRule begin
WARNING: [SetPropertiesRule]{Server/Service/Engine/Host/Context} Setting property 'source' to 'org.eclipse.jst.jee.server:FinalProject' did not find a matching property.
Jun 12, 2010 1:25:08 PM org.apache.catalina.core.AprLifecycleListener init
INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Program Files\java\jdk1.6.0_16\jre\bin;.;C:\Windows\Sun\Java\bin;C:\ Windows\system32;C:\Windows;C:/Program Files/Java/jre6/bin/client;C:/Program Files/Java/jre6/bin;C:\Perl\site\bin;C:\Perl\bin;C:\Program Files\Java\jre1.6.0\bin;c:\Program Files\Microsoft SQL Server\90\Tools\binn\;C:\Program Files\PharosSystems\OutputManagement;C:\Program Files\PharosSystems\Core;C:\Program Files\QuickTime\QTSystem\;C:\Program Files\MySQL\MySQL Server 5.1\bin;;c:\program files\java\jre1.6.0\bin;C:\Sun\AppServer\bin;C:\Sun\Appserve r\lib\ant\bin;C:\windows\system32;C:\Program Files\Apache Software Foundation\Tomcat 6.0\bin;C:\Program Files\Common Files\Ahead\Lib\
Jun 12, 2010 1:25:08 PM org.apache.coyote.http11.Http11Protocol init
INFO: Initializing Coyote HTTP/1.1 on http-8080
Jun 12, 2010 1:25:08 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 588 ms
Jun 12, 2010 1:25:08 PM org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
Jun 12, 2010 1:25:08 PM org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/6.0.18
Jun 12, 2010 1:25:08 PM org.apache.tomcat.util.digester.Digester endElement
SEVERE: End event threw exception
java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.apache.tomcat.util.IntrospectionUtils.callMethodN(Intros pectionUtils.java:953)
at org.apache.catalina.startup.CallMethodMultiRule.end(WebRuleS et.java:789)
at org.apache.tomcat.util.digester.Rule.end(Rule.java:229)
at org.apache.tomcat.util.digester.Digester.endElement(Digester .java:1140)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .endElement(AbstractSAXParser.java:601)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanEndElement(XMLDocumentFragmentScannerImpl.jav a:1774)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDriver.next(XMLDocumentFragmentSca nnerImpl.java:2930)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.next(XMLDocumentScannerImpl.java:648)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java: 510)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:807)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:737)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(X MLParser.java:107)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(AbstractSAXParser.java:1205)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(SAXParserImpl.java:522)
at org.apache.tomcat.util.digester.Digester.parse(Digester.java :1644)
at org.apache.catalina.startup.ContextConfig.processDefaultWebC onfig(ContextConfig.java:687)
at org.apache.catalina.startup.ContextConfig.defaultWebConfig(C ontextConfig.java:624)
at org.apache.catalina.startup.ContextConfig.start(ContextConfi g.java:1065)
at org.apache.catalina.startup.ContextConfig.lifecycleEvent(Con textConfig.java:261)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent (LifecycleSupport.java:117)
at org.apache.catalina.core.StandardContext.start(StandardConte xt.java:4252)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.j ava:1045)
at org.apache.catalina.core.StandardHost.start(StandardHost.jav a:719)
at org.apache.catalina.core.StandardEngine.start(StandardEngine .java:443)
at org.apache.catalina.core.StandardService.start(StandardServi ce.java:516)
at org.apache.catalina.core.StandardServer.start(StandardServer .java:710)
at org.apache.catalina.startup.Catalina.start(Catalina.java:578 )
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:2 88)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:41 3)
Caused by: java.lang.IllegalArgumentException: Servlet mapping specifies an unknown servlet name invoker
at org.apache.catalina.core.StandardContext.addServletMapping(S tandardContext.java:2393)
at org.apache.catalina.core.StandardContext.addServletMapping(S tandardContext.java:2373)
... 38 more
Jun 12, 2010 1:25:08 PM org.apache.catalina.startup.ContextConfig processDefaultWebConfig
SEVERE: Parse error in default web.xml
at org.apache.tomcat.util.digester.Digester.createSAXException( Digester.java:2808)
at org.apache.tomcat.util.digester.Digester.createSAXException( Digester.java:2834)
at org.apache.tomcat.util.digester.Digester.endElement(Digester .java:1143)
... 30 more
SEVERE: Occurred at line 396 column 23
Jun 12, 2010 1:25:08 PM org.apache.catalina.startup.ContextConfig start
SEVERE: Marking this application unavailable due to previous error(s)
Jun 12, 2010 1:25:08 PM org.apache.catalina.core.StandardContext start
SEVERE: Error getConfigured
SEVERE: Context [] startup failed due to previous errors
... 38 more
... 30 more
at sun.reflect.GeneratedMethodAccessor19.invoke(Unknown Source)
at org.apache.tomcat.util.IntrospectionUtils.callMethod1(Intros pectionUtils.java:922)
at org.apache.tomcat.util.digester.SetNextRule.end(SetNextRule. java:193)
at org.apache.catalina.startup.ContextConfig.applicationWebConf ig(ContextConfig.java:365)
at org.apache.catalina.startup.ContextConfig.start(ContextConfi g.java:1066)
Caused by: java.lang.IllegalArgumentException: addChild: Child name 'CommonsFileUploadServlet' is not unique
at org.apache.catalina.core.ContainerBase.addChildInternal(Cont ainerBase.java:781)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBas e.java:771)
at org.apache.catalina.core.StandardContext.addChild(StandardCo ntext.java:2037)
... 36 more
Jun 12, 2010 1:25:08 PM org.apache.catalina.startup.ContextConfig applicationWebConfig
SEVERE: Parse error in application web.xml file at jndi:/localhost/FinalProject/WEB-INF/web.xml
... 29 more
SEVERE: Occurred at line 162 column 13
SEVERE: Context [/FinalProject] startup failed due to previous errors
Jun 12, 2010 1:25:08 PM org.apache.coyote.http11.Http11Protocol start
INFO: Starting Coyote HTTP/1.1 on http-8080
Jun 12, 2010 1:25:09 PM org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
Jun 12, 2010 1:25:09 PM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/27 config=null
Jun 12, 2010 1:25:09 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 523 ms
Previous Topic:Eclipse 3.4.2 reads XMI 2.1 with errors!
Next Topic:Problems with KM3 metamodel org.eclipse.gmt.tcs.injector.KM3_ANTLR3Lexer
Current Time: Sat May 25 13:19:07 EDT 2013
Powered by FUDForum. Page generated in 0.01644 seconds
