Home » Archived » IAM (Eclipse Integration for Apache Maven) » How to run maven goal after compile
How to run maven goal after compile [message #539719] Sat, 12 June 2010 02:50 Go to next message
Niranjan  is currently offline Niranjan
Using Eclipse 3.3.2.
I have imported maven project in eclipse. I want to run maven test goal every time my project is compiled. Ideally I want to run one particular junit test suite every time I save files since build automatically is checked and see the results in junit runner of eclipse.
I tried creating additional builder but it always resulted into corrupting my project file and corrupting my original maven builder. Eclipses shows invalid launcher for both Java and Maven project builder.
Is there any way I can achieve this?
Thanks in advance.
Re: How to run maven goal after compile [message #539767 is a reply to message #539719] Sat, 12 June 2010 14:41 Go to previous message
Carlos Sanchez is currently offline Carlos Sanchez
Maven is not compiling the classes, just generating the resources and
test resources, Eclipse compiles the classes when it detects changes.
You can create run configurations to run junit tests in eclipse ot run
maven goals, but I"m not sure how to do that automatically in the IDE,
usually that's done at the Continuous Integration server
On 6/12/10 8:50 AM, Niranjan wrote:
> Thanks in advance.
Previous Topic:How to run maven goal after compile
Next Topic:Creating Maven projects
Current Time: Fri May 24 08:32:48 EDT 2013
Powered by FUDForum. Page generated in 0.01731 seconds
