Home » Eclipse Projects » Web Tools Project (WTP) » What is the correct version of Java EE to use
What is the correct version of Java EE to use [message #539021] Wed, 09 June 2010 06:38 Go to next message
Eclipse User
Originally posted by: reefedjib.yahoo.com
I just downloaded Galileo, Java EE 5, jdk 1.6, and other software (OC4J,
MySQL, Subversion, Subclipse). I had trouble locating an ejb.jar and so I
had a bad import javax.ejb.Local. This was before I had added OC4J as a
Runtime Environment. So, I decided to install Java EE 4 and jdk 1.5. This
worked and resolved my Local.
Now that I have OC4J, which brings its own ejb.jar file, should I switch
back to Java EE 5?
Re: What is the correct version of Java EE to use [message #539106 is a reply to message #539021] Wed, 09 June 2010 12:01 Go to previous messageGo to next message
Konstantin Komissarchik is currently offline Konstantin Komissarchik
Different application servers support different versions of the Java EE spec. They are typically backwards compatible, but they are not going to be forward compatible. If the app server says its a J2EE 1.4 server, you will not be able to run apps written for Java EE 5 (or related technologies such as EJB 3.0) on it.
The best thing to do is to not try to configure Java EE libraries yourself. Set your project to target the server runtime that you intend the application to run on. If the project already exists, you can do that under Project Properties -> Targeted Runtimes.
- Konstantin
Re: What is the correct version of Java EE to use [message #539310 is a reply to message #539106] Thu, 10 June 2010 07:07 Go to previous message
Eclipse User
Thanks for your responses. I am combining multiple responses.
"Konstantin Komissarchik" <konstantin.komissarchik@oracle.com> wrote in
message news:huodsr$9q8$1@build.eclipse.org...
> - Konstantin
When I installed OC4J as a Target Runtime, this is what I have done. I
created the Project after installing the Runtime.
message news:huoe0n$c3m$1@build.eclipse.org...
> OC4J 10.1.3.4 is a J2EE 1.4 app server. It is not compatible with Java EE
> 5 technologies such as EJB 3.0. Your EAR file isn't being recognized by
> the server because it doesn't look like a valid J2EE 1.4 application.
> - Konstantin
This makes sense. I didn't realize OC4J was a J2EE 1.4 app server.
message news:huoebo$i4n$1@build.eclipse.org...
>> I have Galileo and Java EE 4. I installed OC4J as a Runtime Environment
>> and got its ejb.jar. My first question is that Java EE doesn't seem to
>> have any jars or libraries configured in Galileo. What is it good for?
> The best way to make sure that your application is compatible with the app
> server that you intend to deploy is to set your project to target that app
> server.
The problem I see is I was able to create a 3.0 EJB Project, so I could use
the Wizards to build Beans. It didn't restrict me to 2.1 because OC4J is a
I have now created a EJB 2.1 project and am having to manually add my
classes.
Rob
Previous Topic:specifying help id for the XML editor
Next Topic:Making sense of Java EE and Galileo
Current Time: Fri May 24 06:00:37 EDT 2013
Powered by FUDForum. Page generated in 0.01710 seconds
