| Sorting Contactlist [message #538989] |
Wed, 09 June 2010 05:28  |
Malte Bauer Messages: 2 Registered: June 2010 |
Junior Member |
i have included the ECF perspective in my RCP. Its works great, but my contactlist is not sorted. Is it possible to sort the contacts by name?
best regards
malte
| Re: Sorting Contactlist [message #539662 is a reply to message #538989] |
Fri, 11 June 2010 14:04  |
Scott Lewis Messages: 942 Registered: July 2009 |
Hi Malte,
With the current implementation (ECF 3.3/Helios), the contact list is
not sorted.
It would be a technically easy addition to make, however...and if you
would like to do it yourself (and perhaps contribute it back to ECF
project) it would be most appreciated.
You might want to propose this as an enhancement. To do so, open a
bug/enhancement here:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=ECF
Also, you can/could rally implementation support among the existing
committers and community via the ecf-dev mailing list (here to join:
https://dev.eclipse.org/mailman/listinfo/ecf-dev
And, in case you are able/willing to work with the code yourself to make
the enhancement, the relevant class for this is in this project
org.eclipse.ecf.presence.ui
In this class: org.eclipse.ecf.presence.ui.MultiRosterView
The original author of this code was Remy Suen, an ECF committer who
regularly reads the ecf-dev mailing list, but does not regularly read
this newsgroup. If you made a post to the ecf-dev mailing list you
might be able to enlist his involvement/help in adding this feature.
Scott
Malte Bauer wrote:
> Hello,
> best regards
> malte
| Re: Sorting Contactlist [message #625271 is a reply to message #538989] |
Hi Malte,
not sorted.
Scott
Malte Bauer wrote:
> Hello,
> best regards
> malte
FUDForum. Page generated in 0.01825 seconds
