| Deployment in SCA and SCA Tools [message #537755] |
Thu, 03 June 2010 10:50  |
Eclipse User Messages: 243 Registered: July 2009 |
I would like to know if the deplyment of domain occurs in one or two or
multiple phases. What follows are some thoughts from S. Roderick:
<comment>
A one phase deployment works like this:
<code>
load deployment file
for all components listed in deployment file
configure component
if any component failed to configure then exit
start component
</code>
The problem comes when one of your components is say a file logging
component attached to the real-time logging, and some other component
fails to configure. You get no logging output as the logging component
hasn't had a chance to start yet!
Multiphase:
What you need is to be able to completely configure and start all your
logging _service components_, and then attempt to configure/start your
application components
</comment>
How does deployment work in SCA? How does the SCA Tools support deployment?
-H
| Re: Deployment in SCA and SCA Tools [message #538282 is a reply to message #537755] |
Mon, 07 June 2010 04:21  |
Vincent Zurczak Messages: 139 Registered: July 2009 |
Hello Hugo,
My answers below.
Le 03/06/2010 16:50, Hugo A. Garcia a écrit :
> Hi
> <comment>
> <code>
> configure component
> start component
> </code>
> Multiphase:
> </comment>
Honestly, I am not sure there is a unique way.
IMO, deployment depends on the target platform.
Currently, we try to support 3 different platforms: Apache Tuscany, OW2
FraSCAti and Fabric3. You should see with them directly for this question.
SCA Tools support a very basic deployment.
We do not support the notion of "domain", since only Tuscany implemented
it and documented it. And we do not really support SCA servers, but SCA
runtime libraries (meaning we expect an SCA application with the runtime
libraries in its class path).
What we provide is simply a convenient way to deploy an SCA application
on a SCA runtime. But it is only intended for development, as it does
not offer many options and interactions with the runtime.
A more advanced solution would go through the definition of servers in
Eclipse, just like Tomcat and JEE servers. This would help in debugging
and following execution. Once again, that would still be intended for
development steps.
In production steps, Eclipse should not be used. People generally prefer
scripts to deploy (ANT, Maven). Given our current priorities, SCA server
support (something similar to what exist for Tomcat) would rather wait
for external contributions. It is not on our own roadmap.
Vincent.
| Re: Deployment in SCA and SCA Tools [message #577302 is a reply to message #537755] |
Hello Hugo,
My answers below.
> Hi
> <comment>
> <code>
> configure component
> start component
> </code>
> Multiphase:
> </comment>
development steps.
Vincent.
FUDForum. Page generated in 0.01695 seconds
