Home » Modeling » OCL » duplicate classes in a single package
duplicate classes in a single package [message #537488] Wed, 02 June 2010 11:26 Go to next message
pkojo is currently offline pkojo
I am trying to find duplicate classes in a package, when I run my query it provides all duplicate classes from all packages of the model.
My question is how can I find duplicate classes in a single package.
right now I am running following query by selecting Packages as a context in eclipse OCL Interpreter console.
Class.allInstances()->select(n1|Class.allInstances()->exists(n2|n1<>n2 and n1.name = n2.name))->asSet()->select(oclIsTypeOf(Class))
Thanks in advance,
Re: duplicate classes in a single package [message #537511 is a reply to message #537488] Wed, 02 June 2010 12:34 Go to previous messageGo to next message
Hi pkojo
If you require 'n1.package = n2.package', then 'and' it with your exists
predicate
Your search will go quicker if you do Package.allInstances, then
do subloops of the package classifiers thereby rendering the same
package test redundant and excluding interpackage explorations from
the search domain.
Ed Willink
On 02/06/2010 16:26, pkojo wrote:
> Hi
> Class.allInstances()->select(n1|Class.allInstances()->exists(n2|n1 <>n2
> Thanks in advance,
Re: duplicate classes in a single package [message #537658 is a reply to message #537511] Thu, 03 June 2010 05:44 Go to previous messageGo to next message
Hi Ed,
Thanks for the response but I did not get your point. can you please explain it with example query.
If you require 'n1.package = n2.package', then 'and' it with your exists predicate
from this it looks that you are talking about duplicate packages. but I am looking for duplicate classes in a same package. I am running that query on a package.
pkojo
Re: duplicate classes in a single package [message #537672 is a reply to message #537658] Thu, 03 June 2010 06:15 Go to previous message
I rewrite my query like this and it works fine.
context Package
 self.member->select(n1| self.member->exists(n2| n2 <> n1 and n1.name = n2.name))->select(oclIsTypeOf(Class))->asSet()
Previous Topic:EConstraint in Ecore Model
Next Topic:how to attach ocl constraint to uml class
Current Time: Tue May 21 21:17:38 EDT 2013
Powered by FUDForum. Page generated in 0.01716 seconds
