Home » Eclipse Projects » Platform - User Assistance (UA) » Infocenter -- what URL will load the infocenter and run a search immediately?
Infocenter -- what URL will load the infocenter and run a search immediately? [message #537490] Wed, 02 June 2010 11:30 Go to next message
Eddie Galvez is currently offline Eddie Galvez
We have an infocenter, but I cannot find a URL that will load the infocenter and immediately issue a query. The use case is simple, it is to provide users with a search form elsewhere, that then would load the infocenter.
The closest I've come is (for example)
http://help.eclipse.org/galileo/advanced/searchView.jsp?sear chWord=infocenter&maxHits=500&workingSet=All+topics
but that doesn't work, I think that usually works alongside some of the other frames...
Re: Infocenter -- what URL will load the infocenter and run a search immediately? [message #538549 is a reply to message #537490] Mon, 07 June 2010 18:50 Go to previous messageGo to next message
Chris Goldthorpe is currently offline Chris Goldthorpe
Eddie Galvez wrote on Wed, 02 June 2010 11:30
Try this:
http://help.eclipse.org/galileo/index.jsp?tab=search&sea rchWord=help
Re: Infocenter -- what URL will load the infocenter and run a search immediately? [message #538809 is a reply to message #538549] Tue, 08 June 2010 13:03 Go to previous messageGo to next message
Thank you! that works.
Might want to add that to the documentation?
Re: Infocenter -- what URL will load the infocenter and run a search immediately? [message #541212 is a reply to message #538809] Fri, 18 June 2010 13:43 Go to previous message
Eddie Galvez wrote on Tue, 08 June 2010 13:03
Good idea - if you can open a bug report I'll make sure it gets added.
Re: Infocenter -- what URL will load the infocenter and run a search immediately? [message #624169 is a reply to message #538549] Tue, 08 June 2010 13:03 Go to previous message
Re: Infocenter -- what URL will load the infocenter and run a search immediately? [message #624182 is a reply to message #538809] Fri, 18 June 2010 13:43 Go to previous message
Previous Topic:in standalone help system,Search don't work for me
Next Topic:Cheat Sheets in Menu
Current Time: Thu May 23 05:10:21 EDT 2013
Powered by FUDForum. Page generated in 0.01637 seconds
