| Attribute named 'function' in ETL [message #537211] |
Tue, 01 June 2010 11:09  |
Originally posted by: c.k.holmes.lboro.ac.uk
If a metamodel class has an attribute named 'function' then it appears
to cause problems within an ETL rule:
(1)rule MyRule
(2) transform inItem : Source!InputModelElement
(3) to outItem : Target!OutputModelElement {
(4) outItem.name := inItem.function;
(5) outItem.number := inItem.number.asInteger();
(6)}
Line 4 won't parse as it stands, 'function' appears to be a reserved
word in ETL (EOL?). Can I escape the attribute name in some way?
Chris
| Re: Attribute named 'function' in ETL [message #537213 is a reply to message #537212] |
Tue, 01 June 2010 11:23  |
Thanks Dimitris:)
Best Wishes
Chris
Dimitris Kolovos wrote:
> Hi Chris,
> You can use backticks to escape reserved words. E.g.
> outItem.name := inItem.`function`;
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> (1)rule MyRule
>> (6)}
>> Regards
>> Chris
| Re: Attribute named 'function' in ETL [message #589624 is a reply to message #537211] |
Tue, 01 June 2010 11:12  |
Dimitrios Kolovos Messages: 1772 Registered: July 2009 |
Hi Chris,
Dimitris
Chris Holmes wrote:
> (1)rule MyRule
> (6)}
> Regards
> Chris
| Re: Attribute named 'function' in ETL [message #589637 is a reply to message #537212] |
Thanks Dimitris:)
Best Wishes
Chris
> Hi Chris,
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> (1)rule MyRule
>> (6)}
>> Regards
>> Chris
FUDForum. Page generated in 0.01647 seconds
