Home » Eclipse Projects » Web Tools Project (WTP) » Eclipse is trying to access port 80 when before compile(Eclipse)
Eclipse is trying to access port 80 when before compile [message #536607] Fri, 28 May 2010 17:18 Go to next message
angel50  is currently offline angel50
I am running Eclipse on a closed intranet network;
When I first start eclipse for the day, eclipse is very slow to start up, get a not responding for over a minute!
a "netstat -aon" shows that Eclipse is trying to access some address on port 80 and eclipse locks up until the connection times out since it cannot access that port 80 request;
Is there a way to disable that initial port 80 request when I start Eclipse? Change the behavior; etc...
thank You;
Angel50
Re: Eclipse is trying to access port 80 when before compile [message #536617 is a reply to message #536607] Fri, 28 May 2010 18:19 Go to previous messageGo to next message
Russell Bateman is currently offline Russell Bateman
> thank You;
> Angel50
Do you have Eclipse set up to update associated software automatically?
Re: Eclipse is trying to access port 80 when before compile [message #536623 is a reply to message #536617] Fri, 28 May 2010 18:34 Go to previous message
I configured Eclipse NOT to update automatically.
Previous Topic:latest saxon not working with wtp xslt plugin
Next Topic:Web Project Composed of various svn resources
Current Time: Tue May 21 10:04:35 EDT 2013
Powered by FUDForum. Page generated in 0.01564 seconds
